It is currently Sat May 25, 2019 4:52 am
 Post subject: Code 0303
PostPosted: Tue May 29, 2018 10:06 am
Hello,
I have developed a horrible mis-fire and code P0303.
Before I start throwing money at this 2001 SE, can you recommend a no cost route?
It's worse when its humid or wet outside.
I have read that it could be:
Bad coil
Bad plug
Bad wire
Bad ICM
Thanks in advance.
Lee
 Post subject: Re: Code 0303
PostPosted: Tue May 29, 2018 12:27 pm
first see if the wire boot is seated on the #3 cylinder properly - follow the wire from the coil that is marked 3 to find 3 cylinder and plug.
PostPosted: Tue May 29, 2018 2:15 pm
You can always move the coils around and see if the misfire follows, same goes for similar length wires.
PostPosted: Fri Jun 01, 2018 8:45 am
I ohmed the wire on cylinder number 3 and it read infinity. Swapped it out and miss is gone.
Thanks.
PostPosted: Fri Jun 01, 2018 9:39 am
Good to hear!
There are no new unread posts for this topic. Misfire, code 0303, plugs wires changed. Injector?
kennedyrec
Sat Mar 10, 2012 10:52 am
robauto View the latest post
There are no new unread posts for this topic. P0420 code fixed now (new cat) now p1441 code
gold8165
Sat Jun 25, 2011 4:14 pm
mrbul35 View the latest post
There are no new unread posts for this topic. New Code for me
rrounds
Thu May 06, 2010 9:41 pm
Archon View the latest post
There are no new unread posts for this topic. 420 code
Oldman
Thu Jul 23, 2015 4:51 pm
MKMike View the latest post
There are no new unread posts for this topic. MAF code
jim01028
Sat Jun 29, 2013 5:41 pm
rmorton View the latest post
