It is currently Mon Jan 21, 2019 3:54 pm
 Post subject: Coolant temp gauge
PostPosted: Mon May 21, 2018 12:50 pm
Year and Trim: 2002 Park avenue
While doing some work on my ac, I disconnected my battery, took the bottom part of the dash off (the black plastic peice above the pedals) and unplgged anything connected to said peice of plastic. Ive temporarily fixed my ac, but I went to start the var and the coolant temp gauge has not only gone all the way to the "H" but past it all the way back around to the peg under the "C". How can I fix this?
 Post subject: Re: Coolant temp gauge
PostPosted: Mon May 21, 2018 7:28 pm
does it register properly when engine heats?
PostPosted: Tue May 22, 2018 12:48 pm
Nops, staying in the same place. The coolant temp on the digital screen reads the temp correctly
PostPosted: Tue May 22, 2018 1:34 pm
ok, then I would assume the servo for gauge is funky - did you check the wiring for servo?
also,check the plug for colant temp sender - maybe you left it unplugged
PostPosted: Sun May 27, 2018 10:29 am
I ended up just using the "magnet trick" and it took 2 min and worked perfectly
PostPosted: Sun May 27, 2018 4:28 pm
cool, what is this trick?
There are no new unread posts for this topic. Water Temp gauge
Mac077
Wed Jun 30, 2010 5:09 pm
Mac077 View the latest post
There are no new unread posts for this topic. Coolant Temp with 180 Stat
ColoBonne
Fri Aug 15, 2008 6:15 pm
There are no new unread posts for this topic. Coolant Temp **How hot does your SSEi get**
Schweet97Z
Thu Jul 29, 2010 7:28 am
Schweet97Z View the latest post
There are no new unread posts for this topic. Coolant temp not working right
bigtoxi
Sat Oct 08, 2011 10:36 am
There are no new unread posts for this topic. Coolant Temp too Low Code?
redzmonte
Sat Dec 24, 2011 2:19 pm
