It is currently Mon Feb 18, 2019 1:50 am
 Post subject: Aluminum Coolant Elbows
PostPosted: Mon May 21, 2018 10:41 am
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
I have a 2001 SLE and installed aluminum coolant elbows about 1 1/2 years ago.
The other day is was leaking antifreeze and I found out is was coming from the coolant elbows.
After taking it apart I found out that the O-rings on the elbows had completely disintegrated.
I am thinking that the cheap Chinese material that they used was probably not a Viton material.
I now think I will go with the original GM plastic elbows which probably have the correct O-ring material.
I also could switch the O-rings from the plastics ones and use on the aluminum ones.
Has anyone else encountered this problem?
PostPosted: Mon May 21, 2018 11:12 am
I'd put new o-rings on. Going to plastic will leave you right where you began. You'll also want to make sure there isn't any flashing in the ring grooves, damaging the o-ring.
PostPosted: Mon May 21, 2018 12:11 pm
IIRC Andrew had a similar problem with the o-rings on the metal elbows. I did a quick search here, and couldn't find it. It's possible that it was on Facebook. I don't recall what o-rings (if any) were used as a replacement, but it was believed that by now the problem had been solved. So, you might just want to replace the elbows with new.
PostPosted: Mon May 21, 2018 12:49 pm
1975 Monte Carlo
The holes where the elbows fit into were clean and smooth.
The problem is that the material that the O-rings were made of fell apart.
I know in the past I have had problems with material from China where O-rings have failed.
I am going to buy the GM OEM plastic ones and use those O-rings on the new aluminum ones.
It is really frustrating that I thought I took care of this issue and now I have to take care of it again.
Nothing ticks me off more than having to redo something that I did correct in the first place and then redo again.
Maybe I am paranoid (my wife would agree) but I have no faith in items from China.
The problem is in a lot cases you have no choice.
So much for my rant!!!
Thanks for your replies.
PostPosted: Mon May 21, 2018 1:03 pm
I was referring to the grooves on the elbow that the o-rings sit in.
PostPosted: Mon May 21, 2018 1:16 pm
1975 Monte Carlo
O.K.
I will check and make sure they are good.
Thanks.
PostPosted: Mon May 21, 2018 5:08 pm
I replace the Dorman o-rings on every set I install, they are junk.
I use AC Delco 24502846 & 25537068.
-Andrew-
PostPosted: Mon May 21, 2018 7:29 pm
1975 Monte Carlo
harofreak00 thank you for the part numbers.
Do you know how many of each I need for the 2 elbows?
I believe 3 are one size and the other is another size.
Thank you.
PostPosted: Tue May 22, 2018 10:40 am
smaller: 25537068 x3
larger: 24502846 x1
I have these in stock if you want me to just drop them in an envelope for you. PM me if interested.
-Andrew-
PostPosted: Tue May 22, 2018 3:46 pm
1975 Monte Carlo
Thank you for the information & offer.
I ordered some already.
Should have in a couple of days.
Thanks again.
PostPosted: Wed May 23, 2018 6:59 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Just repaired a car yesterday that had Dorman elbows already installed, but one of the O rings had failed. Looks like we'll be stocking these O rings, and putting them on the replacement elbows. Thanks!!
There are no new unread posts for this topic. Aluminum Coolant Elbows
rkhodges21
Wed Apr 08, 2015 2:38 pm
There are no new unread posts for this topic. coolant elbows
irish91983
Sun Sep 04, 2011 1:14 pm
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. LIM and coolant elbows
1oldman
Thu Aug 22, 2013 7:04 pm
There are no new unread posts for this topic. Coolant Elbows
97seagain
Thu Dec 08, 2011 8:42 pm
Mark Fahey View the latest post
There are no new unread posts for this topic. Do coolant elbows without removing uim and lim?
agrazela
12
1476
Mon May 16, 2016 1:08 pm
MKMike View the latest post
Users browsing this forum: Google [Bot] and 9 guests
