It is currently Wed Jan 23, 2019 9:01 pm
PostPosted: Sat May 12, 2018 12:35 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
I have to replace the rear crankcase cover gasket, as it has blown out and created a huge coolant leak.
Not looking to do extra work or to make things more complicated.
Which is the easier to do option; Pull engine & transmission; pull transmission or just pull the engine?
How does anyone get the nose of the car high enough to remove anything from the bottom?
I already have bars to support the engine, from a subframe change but am not averse to getting a hoist and engine stand.
Just looking to save myself grief.
Kind of shocked that at 90K my engine needs such a repair.
PostPosted: Sat May 12, 2018 1:50 pm
Year and Trim: 2002 sle
Pull the engine using a cherry picker! Not that bad of a job!
PostPosted: Sat May 12, 2018 3:19 pm
1998 SE
2001 SSEI
2002 SSEI
Thanks, Michtom.
So, just the engine alone?
Any decent brands--or brands to avoid?
PostPosted: Sat May 12, 2018 5:10 pm
Yes, engine alone! Much easier if you don’t have a hoist. Otherwise you would remove the transmission to access! No suggestions for gaskets other than quality, as you don’t want to do the job again.
PostPosted: Sat May 12, 2018 8:03 pm
1998 SE
2001 SSEI
2002 SSEI
Thanks again!
I should have been clear, I was wondering which brands make good quality cherry pickers.
PostPosted: Sat May 12, 2018 8:42 pm
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
I have never heard of replacing the rear crankcase cover gasket.
Is that an unusual problem?
90K is nothing on these engines.
I just passed 150K on the 2001 and have 259K on the 2000.
Sorry to hear about this problem.
PostPosted: Sun May 13, 2018 7:07 pm
1998 SE
2001 SSEI
2002 SSEI
Been told it isn't uncommon.
Perhaps it tended to occur on some years and not others.
This one is a 2002 SSEI.
Anyone who has knowledge of which brands are/aren't good on the hydraulic engine cranes/cherry pickers or whatever name you prefer, I'd appreciate if you let me know.
PostPosted: Tue May 15, 2018 9:03 am
I had a project car with that rear crankcase cover gasket leak, the coolant just poured out. With a lift, its easier to drop the trans out the bottom and fix it in the car, but if you only have a cherry picker, the engine out the top is the best way. I wouldn't worry about the brand, the 500lb engine is well within the specs for even the cheapest lifts.
-Andrew-
PostPosted: Tue May 15, 2018 1:14 pm
1998 SE
2001 SSEI
2002 SSEI
I had hoped you'd reply, as you have the most experience in Bonneville repairs.
Thank you.
As for lifts, what brand do you recommend for home lifts?
I don't have a cherry picker or lift, yet.
Thanks again.
PostPosted: Tue May 15, 2018 2:48 pm
Harbor Freight or Northern Tool for the cherry picker would be fine.
The lift I have in my shop is an Eagle Lift, about 20 years old. The lift was here when I bought the building. I have no idea what I'd recommend for a home use situation.
-Andrew-
PostPosted: Tue May 15, 2018 4:15 pm
1998 SE
2001 SSEI
2002 SSEI
Thanks again!
There are no new unread posts for this topic. Engine Knock? Easier to replace or rebuild engine? tranny?
welchartgalleria
Sat Mar 17, 2012 9:32 pm
chelbanger View the latest post
There are no new unread posts for this topic. Separating Engine from Trans
97seagain
Mon May 30, 2011 12:24 am
There are no new unread posts for this topic. Trying to pinpoint engine/trans noise
flatlander745
Sat Mar 08, 2014 2:29 pm
There are no new unread posts for this topic. Radial Pull
white06lacrossecxs
Sat Nov 08, 2008 9:55 am
There are no new unread posts for this topic. Transmission won't pull
mrbonne
Fri Jul 05, 2013 10:34 am
mrbonne View the latest post
