It is currently Wed Jan 23, 2019 7:44 pm
 Post subject: blend door?
PostPosted: Fri Apr 27, 2018 1:29 pm
Year and Trim: 2000 & 2005
Sorry... tried to find a post but no luck on this one.
2000 Bonneville with manual AC /Heat controls. Cold air only blowing out of front dash panel on the two right side vents. The two drivers side vents do not blow cold.
I believe it is a blend door but which one is it and how do I locate it? Will this be a hard fix?
Thanks for any help I can get with what the problem is and how to fix.
Jeff
 Post subject: Re: blend door?
PostPosted: Fri Apr 27, 2018 1:34 pm
Sorry thought should clarify a little more.
The drivers side left two vents blow air but just not cold air like the right two do.
thanks again
PostPosted: Fri Apr 27, 2018 2:15 pm
pass side colder than drivers may be a sign of low system charge - check that first.
PostPosted: Fri Apr 27, 2018 2:24 pm
It would be a blend door problem if all the vents blew only cold air.
'02 Pontiac Bonneville SE 105k miles, N/A, SSEi exhaust system.
PostPosted: Fri Apr 27, 2018 2:44 pm
I did just add a can of refrigerant, old cheapo gauge read in the green zone afterwards.
PostPosted: Fri Apr 27, 2018 9:00 pm
accuracy is questionable so go by weight - 1 can should be equal to 1 pound and we need 2-2.5 lbs so maybe add another can and watch the pressure.
There are no new unread posts for this topic. BIG blend door actuator problems---HELP
Frazzled
Mon Aug 29, 2011 6:08 pm
There are no new unread posts for this topic. Passenger blend door actuator
marrober9
11
3208
Sat Feb 01, 2014 3:12 am
marrober9 View the latest post
There are no new unread posts for this topic. 2000 Bonneville Blend Door Actuators
dougtoth
Tue Apr 11, 2017 7:17 pm
scooberu View the latest post
There are no new unread posts for this topic. manual Heater Blend Door Actuator install 2000 bonneville
jcweis1
Tue Nov 08, 2016 5:11 pm
Archon View the latest post
There are no new unread posts for this topic. door adjustment
Sun Jul 06, 2008 11:40 am
cron
