It is currently Wed Jan 23, 2019 7:52 pm
PostPosted: Sun Apr 15, 2018 12:03 pm
The auto leveling system in my 2000 SLE has suddenly been pumping up my rear shocks to the max. Super high like a punks hot rod from the 70s. Super firm as well. Periodically I hear what i suspect is a pressure relief valve hissing. Then the compressor kicks in for a bit.
I suspect it's the ride height sensor, but wanted to get some input before I went there. Anyone have experience with this?
Is there a way to test this? What happens if you disconnect the ride height sensor connector? What if I disco the link tot the control arm and manually move it? the suspension should adjust up or down if I move the sensor manually, correct?
Thanks
PostPosted: Sun Apr 15, 2018 3:47 pm
2003 SSEi
2004 GXP
Disconnect arm and it will pump all the way up. Pull the fuse and it should return to normal none functional.
02 SSEI, 1.94 Yella Terra,Gen5 , N*,2-1/4""Phenolic Intercooler,
I SELL, Phenolic Intercoolers, Pulley Pullers, Throttle Bodies, Etc...!!
PostPosted: Mon Apr 16, 2018 6:17 pm
Thanks for the suggestions. It's already at max height so I tried pulling the fuse.
Nothing happened with the car off so I started it. The suspension did not lower at all.
Put the fuse back in with power off and nothing happened. Turned the car back on and heard some pressure release followed by the compressor kicking in. The suspension did not lower at all.
Any more suggestions? If I disconnect the height sensor connector what would happen?
Thanks again
PostPosted: Thu Apr 19, 2018 3:40 pm
Year and Trim: 2000 SSEI
Ride level sensor might have failed.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Thu Apr 19, 2018 4:52 pm
On my 92, I found the sensor arm had been knocked off the control arm one time, and it pumped the back end all the way up. The end of the arm got stuck on something higher, so it thought the rear end was low.
I think if you remove the connector from the diverter valve that splits air between the shocks and the outlet in the trunk, remove the ELC fuse, then press the valve stem in the trunk outlet, it will let the air out of the system. Maybe you can leave the diverter valve hooked up, I'm not sure.
When my level sensor outright died, twice, the rear end sagged.
PostPosted: Sat Apr 21, 2018 2:14 am
I've seen some of these where water has penetrated the sensor causing it to corrode. If you disconnect the arm, can you move the sensor mechanism freely, or does it appear to be binding? The sensor is probably the first place I'd start. Pull the connector off the sensor and check for signs of corrosion or water intrusion as well. This is a sealed connector so you want to make sure the housing seal and mating surfaces are clean before plugging it back in or you may create a new problem.
There are no new unread posts for this topic. 2004 SE Air ride sensor problem
GSCalifornia
Fri Dec 23, 2016 12:43 pm
sseilmnop View the latest post
There are no new unread posts for this topic. rear air ride
excessive81
Wed Mar 21, 2012 12:24 pm
excessive81 View the latest post
There are no new unread posts for this topic. Rear air ride air pump
Rubidon
Wed Jun 24, 2015 8:52 pm
96 SSEi View the latest post
There are no new unread posts for this topic. I think there is a problem with my rear shocks
alexcoqui
Wed Aug 20, 2008 9:45 am
Archon View the latest post
There are no new unread posts for this topic. Rear suspension problem.
T-Keith
Sun Jul 12, 2009 4:34 pm
T-Keith View the latest post
