It is currently Wed Jan 23, 2019 8:56 pm
PostPosted: Thu Apr 05, 2018 8:03 pm
so I put air in my tire( 12v pump) and then when I turned the key to on, the light kept flashing - the volts were 11.7 by dic, is this normal when the battery is low?
thanks..........
PostPosted: Thu Apr 05, 2018 10:01 pm
Engine running or no?
With something like the air compressor running without the engine, the electrical load will go directly onto the battery.
PostPosted: Thu Apr 05, 2018 11:05 pm
no
PostPosted: Fri Apr 06, 2018 11:35 am
so the light flashes due to low charge?
PostPosted: Sun Apr 08, 2018 4:21 pm
Did you run the engine for 10-15 minutes to charge the battery up?
Was the light still flashing?
I suspect, without reading into one of my past car's service manuals, that is a warning that your battery is
worn. I use a 12 v pump to add air to tires and sometimes don't start the cars for the alternator to handle
the load. But my batteries are in good shape.
There are charts on the net where you can measure the voltage of a battery at rest, after the bubble charge has worn off, and from that
voltage determine how good the battery is.
Or just go to a box store.
I suspect you'll find your battery is worn out--unless you used the pump for a long time draining it.
PostPosted: Sun Apr 08, 2018 6:54 pm
no, I charged with 6 amps for 8 - 10 hours and the light didnt blink when started or cranking - all normal
There are no new unread posts for this topic. Misfiring engine, check engine light flashing
scooberu
Wed Jul 05, 2017 7:02 am
MKMike View the latest post
There are no new unread posts for this topic. SES light flashing after degreasing engine bay.
FiendScurro
Sat May 04, 2013 10:15 pm
There are no new unread posts for this topic. service engine soon light
Newbie2000
68
926
Sun Aug 05, 2018 9:45 am
dougtoth View the latest post
There are no new unread posts for this topic. Check gas cap/service engine soon light is on
03SSEISUPERCHARGED
Sun Aug 24, 2008 1:29 pm
00ssei View the latest post
There are no new unread posts for this topic. Service engine soon light is on. Can i turn it off? Causes?
PronksBonne
Fri May 30, 2014 12:49 am
Archon View the latest post
