It is currently Wed Jan 23, 2019 8:09 pm
 Post subject: Washer Fluid Line
PostPosted: Wed Apr 04, 2018 3:10 pm
Year and Trim: 2005 Bonneville SE
So the line for my windshield washer fluid has deteriorated and snapped about a half inch from the grommet on the firewall or what ever that big plastic is(contains the cabin filter) so now instead of my windshield it sprays on the rear side of my motor :) any suggestions?
2005 SE- Drop in K&N Filter,SSEI Exhaust conversion, MagnaFlow High-Flow Cat., SSL DD865BN Stereo,16 inch walmart wheel covers :)
 Post subject: Re: Washer Fluid Line
PostPosted: Wed Apr 04, 2018 3:41 pm
Year and Trim: 01 SSEI (black)
00 SSEI (green)
A similar thing happened to me on my daily -- the plastic nipple for the washer line stayed in the rubber hose after breaking so I used a small pick to remove it. Used a bit of plastic epoxy to re-attach (held it in place with a a couple sewing needles while it dried). Once dry I used a very small drill bit to make sure the passage was clear -- then just reattached the rubber line and I was all good.
With the drilling part; just be careful not to drill too far and create a new place for washer fluid to escape. For me this was up on top of the cowl so I didn't have any obstructions so not sure how clearance would be for you
PostPosted: Wed Apr 04, 2018 4:42 pm
Messed mine up when replacing the alternator, reconnected the fitting with some vacuum line.
PostPosted: Wed Apr 04, 2018 5:00 pm
yes, you can replace the broken parts with vacuum line - if its a clean break -I used contact cement to hold the line together - worked nicely
PostPosted: Thu Apr 05, 2018 10:33 am
If you want to replace the line, I have good used ones available. PM or email andrew.suderman@gmail.com
-Andrew-
There are no new unread posts for this topic. Windshield Washer Fluid Line Broken
3868
Tue Dec 23, 2008 8:21 pm
There are no new unread posts for this topic. Attachment(s) Washer Fluid Motor
gkaiser124
Mon Nov 24, 2014 8:14 pm
xcbullet View the latest post
There are no new unread posts for this topic. Washer fluid pump dead
RJGill84
Tue Dec 23, 2008 7:32 pm
SuperSLE View the latest post
There are no new unread posts for this topic. Windshield Washer Fluid Button Fell Off
djs
Mon Feb 27, 2012 11:11 pm
kbaldwin11 View the latest post
There are no new unread posts for this topic. '02 se washer fluid pump won't turn on question 2
Night Crawler
Tue Dec 31, 2013 3:16 am
Night Crawler View the latest post
