It is currently Sun May 19, 2019 4:29 pm
 Post subject: Trouble with Bonneville
PostPosted: Sun Feb 18, 2018 5:41 pm
Year and Trim: 2000 Pontiac Bonneville Sei
I've got a 2000 Bonneville 3.8 it is setting a p1374 code for the crankshaft sensor. I've replaced the sensor and cleared the code. It keeps setting the code and now its showing a po135 for the oxygen sensor. Does anyone have any idea's?
PostPosted: Sun Feb 18, 2018 7:25 pm
hi, did you inspect/ clean the plug and wiring?
PostPosted: Mon Feb 19, 2018 8:36 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Possible ignition module
PostPosted: Sun Feb 25, 2018 4:28 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
x2
Bad ignition control module and/or coils will also set this code.
PostPosted: Sun Feb 25, 2018 5:22 pm
1998 SE
2001 SSEI
2002 SSEI
MKMike wrote:
x2
A bad ignition control module and/or coils will also set this code.
A bad coil can also make an icm burn out.
As for the P0135, this will help
http://troubleshootmyvehicle.com/gm/3.8 ... ter-test-1
Let us know what you find.
PostPosted: Thu May 03, 2018 3:31 am
Thanks everyone. I replaced the ignition module and it didn't help. So I did a compression test and number 1,3,2,4 are all running low pressure. So motor is coming out and getting rebuilt this week. I appreciate everything.
PostPosted: Thu May 03, 2018 10:26 pm
1998 SE
2001 SSEI
2002 SSEI
Bummer.
Thanks for letting us know the outcome.
There are no new unread posts for this topic. A/C Trouble
white06lacrossecxs
Wed Aug 06, 2008 1:53 pm
white06lacrossecxs View the latest post
There are no new unread posts for this topic. TROUBLE
KelvinVV
Thu May 09, 2013 10:05 pm
david View the latest post
There are no new unread posts for this topic. Air con trouble
Brudus10
Fri Aug 08, 2014 9:45 pm
Brudus10 View the latest post
There are no new unread posts for this topic. Sea Foam trouble!
Hawley12
Sat Jul 27, 2013 11:16 pm
There are no new unread posts for this topic. AC trouble shoot...
Rickvance320
Wed Jul 18, 2012 12:37 am
