It is currently Tue Jan 22, 2019 9:15 am
PostPosted: Sat Feb 10, 2018 11:07 pm
Year and Trim: 2003 SE
I was pulling put of the drive thru the other night. I sat waiting to turn then I turn my heat on defrost and floor. Suddenly the voltage drops and engine starts to run roughly. When I turned it off it returned to normal. So I did it again and then it started the same problem. I left it on and fluctuated the speed of the blower then it eventually leveled out. Any ideas?
2003 Bonneville se
PostPosted: Sun Feb 11, 2018 5:36 pm
I did have a code come up a week ago for the catalytic converter and wheel speed sensor
But that's about it.
PostPosted: Sun Feb 11, 2018 7:37 pm
welcome to the club Pickles!!
I would first check the battery and alternator output. that happened to one of my W bodies that had a rewound alternator: the headlights would also
PostPosted: Sun Feb 11, 2018 11:07 pm
Sounds like a weak alternator. I'd have the car tested at your nearest auto parts store, it's typically free.
PostPosted: Mon Feb 12, 2018 3:27 pm
I did just recently replace the battery. Thanks for the advice I will be checking the alternator asap. I can just do that myself right? Just check the charging output?
And thanks for the welcoming.
PostPosted: Mon Feb 12, 2018 8:45 pm
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
If you have a multimeter, you can test charging system output AND , also very important check for failing diodes that are adding AC into your car's DC electrical system
http://content.amprobe.com/appnotes/AMP ... ppnote.pdf
Too much AC is bad because it messes with the way all your car's electronics , such as the computer, work.
It can burn out ignition control modules and other significant electrical items.
There are no new unread posts for this topic. engine running rough
mahki08
12
2971
Tue Aug 03, 2010 12:35 am
There are no new unread posts for this topic. Voltage Drop
Sierrabarry
Thu Dec 30, 2010 1:55 pm
Sierrabarry View the latest post
There are no new unread posts for this topic. Voltage drop when ABS activates
Ponch 04
Mon Jan 11, 2010 11:27 am
Ponch 04 View the latest post
There are no new unread posts for this topic. 03' Park Avenue Ultra Voltage Drop
Jfridge92
Fri Oct 30, 2015 1:01 pm
gmman View the latest post
There are no new unread posts for this topic. What should running voltage be?
Nocrank
Mon Nov 12, 2012 1:19 am
Users browsing this forum: Exabot [Bot], Google [Bot] and 6 guests
