It is currently Wed Feb 20, 2019 9:15 am
PostPosted: Mon Jan 08, 2018 2:43 pm
Year and Trim: 2000 & 2005
2000 SE Bonneville with manual heat/ac controls. The defrost has great fan air movement. The dash panel has some air movement but not what it should be. The floor has some air movement on passenger side and none on drivers side. The air is hot on defrost and what air does come out of the other vents.
How many door actuators are there and which ones do you think I need to replace?
I did look at the common problem section but all the pictures I cannot open and show as boxes with and 'X'.
I changed the door actuator on my wife's 2005 Bonneville but it was the outside mix door and not sure if the problem with my 2000 Bonneville is the same or another actuator.
Con someone provide the steps to replace the actuator that I need to replace also would be great help.
THANKS for all the help
PostPosted: Mon Jan 08, 2018 3:24 pm
If you are getting enough heat, the likely suspect is the mode actuator, which directs the airflow. FWIW, while mine had a fair among of air when set to the vents, the amount to the floor was sorely lacking. The mode actuator is the one toward the front that has the blue shielded wire.
Remove the knee bolster, that is the lower part of the dash, on the driver's side. Look up, and toward the center of the dash. With a few twists and turns of your body, you should be able to see it. Adjust the temperature, and see if it seems to have full movement. If not, to remove it, disconnect the wiring, and remove the 3 screws that hold it in.
PostPosted: Mon Jan 08, 2018 4:11 pm
thanks that sounds like my issue. Is the mode actuator a different part number than the door actuator?
PostPosted: Mon Jan 08, 2018 10:23 pm
I'm fairly certain that it is a different part number. You may want to check with Andrew at Bonnevilles Unlimited to see what he may have.
There are no new unread posts for this topic. BIG blend door actuator problems---HELP
Frazzled
Mon Aug 29, 2011 6:08 pm
There are no new unread posts for this topic. How to access passenger air mix door actuator.
2000GreySSEi
Mon Jun 20, 2011 8:43 pm
00bonne View the latest post
There are no new unread posts for this topic. Passenger blend door actuator
marrober9
11
3248
Sat Feb 01, 2014 3:12 am
marrober9 View the latest post
There are no new unread posts for this topic. Fuel filler door actuator push pins
Bonneville'n
Wed May 30, 2018 9:07 am
There are no new unread posts for this topic. manual Heater Blend Door Actuator install 2000 bonneville
jcweis1
Tue Nov 08, 2016 5:11 pm
Archon View the latest post
Users browsing this forum: Google [Bot] and 4 guests
