It is currently Mon Feb 18, 2019 2:15 pm
PostPosted: Thu Jan 04, 2018 11:38 am
Year and Trim: 2005 Bonneville SE
I recently bought a 2005 Bonneville SE with 121k miles. It always starts up great in the mornings and after work if it sits all day. Sometimes when I park it for a short period of time (up to 2 hours sometimes), it starts up but is sputtering for about 5-10 seconds, then it catches and runs great. I usually give it some gas and it comes out of it. I cleaned the throttle body and MAF sensor last week and it has improved, only done it a couple time in a week. I bought a Fuel Pressure Regulator and was going to install it but tested the other one and didn't smell any gas when pulling the vacuum line. It also looks like it has been replaced before. Any other simple ideas to check for or if anyone else had this issue and what was done to correct it. Thanks.
PostPosted: Thu Jan 04, 2018 12:44 pm
welcome to the club!!
since you just got it, I would inspect/change: spark plugs, wires, air and fuel filters. I would also do an oil change just to get a starting point.
PostPosted: Thu Jan 04, 2018 6:31 pm
I've done all of that, including dropped the transmission pan and changed the filter. Also replaced the Intermediate Steering Shaft and cabin filter
PostPosted: Fri Jan 05, 2018 8:11 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Does the car lose coolant?
PostPosted: Fri Jan 05, 2018 1:35 pm
since you state it improved after maf cleaning, I would try unplugging the maf and leave it unplugged for a day or 2 and see what happens - it is old, it may be on the way out.
PostPosted: Mon Jan 08, 2018 10:59 am
Nope!
There are no new unread posts for this topic. P0404, p0442, p1404 codes, rough idle, And trouble starting
comatoast
Mon May 28, 2012 6:25 pm
Jrs3800 View the latest post
There are no new unread posts for this topic. Car not starting
abhi0304
Mon Apr 07, 2014 6:09 pm
EI8HTYSE7EN View the latest post
There are no new unread posts for this topic. Not Starting
Bluechip87
Tue Jan 19, 2016 3:52 pm
Bluechip87 View the latest post
There are no new unread posts for this topic. RPM'S LOW WHEN STARTING CAR
1997SEgreenmonster
Sun Mar 03, 2013 5:08 pm
There are no new unread posts for this topic. Starting Issue
Gagger14
17
933
Tue Oct 16, 2012 11:49 am
Users browsing this forum: peter and 15 guests
