It is currently Mon Feb 18, 2019 3:16 pm
 Post subject: Rear valve cover removal
PostPosted: Wed Jan 03, 2018 11:34 am
Year and Trim: 2000 SE
How much of a curse fest is it to remove the rear valve cover on the 3.8 so I can replace the gasket? It's leaving lots of oil on the ground, I did the front so it must be the rear now.
PostPosted: Wed Jan 03, 2018 12:57 pm
there is lots of stuff you have to remove to get it out. if you pinch its hose, you can remove the coolant overflow and maybe wiggle it out there after unbolted
PostPosted: Wed Jan 03, 2018 1:14 pm
that's what I was afraid of
PostPosted: Wed Jan 03, 2018 1:45 pm
not that bad, just a pain - be careful around the evap lines and solenoid near the wall - the lines get brittle and break easily.
and try to go in from the pass side to avoid the evap lines that run from wall to TB under wiring harness
PostPosted: Thu Jan 04, 2018 5:05 pm
Year and Trim: 01 SSEI (black)
00 SSEI (green)
I've done this twice over the last couple months on 3800 engines -- you've got to commit to removing the alternator and alternator bracket (buy new coolant elbows). Its not too bad of a job with these out of the way.
If the plug wires are old be prepared to get new ones if they break upon removing them; it's a great time to do plugs and wires anyways if they haven't been done recently
PostPosted: Sat Jan 06, 2018 5:05 pm
Year and Trim: 2000 Bonne SE 240k mile and going strong.
I had to remove the bracket/ manifold for the Alternator and broke the elbows (plastic). I found metal replacements in the "help" section at O'Rileys for around $10-12. You may want to replace the grommets as well (they are sold separately). While I had all this torn down I found it was a good (and only time!!) I've been able to see/ check the power steering fluid.
There are no new unread posts for this topic. Rear valve cover?
irish91983
Thu Jan 12, 2012 12:34 pm
irish91983 View the latest post
There are no new unread posts for this topic. Rear valve cover gasket
Abbby
Sun Dec 22, 2013 12:09 pm
There are no new unread posts for this topic. Valve Cover Gaskets A No Go
Jaxstarke99
Fri Jun 16, 2017 8:47 am
There are no new unread posts for this topic. valve cover gaskets......
SLEking
Wed Apr 13, 2011 1:34 pm
There are no new unread posts for this topic. valve cover breathers?
LAIDBACKLUKE
Tue May 24, 2011 2:22 am
LAIDBACKLUKE View the latest post
