It is currently Thu Feb 21, 2019 3:27 am
PostPosted: Wed Dec 27, 2017 8:19 pm
Year and Trim: 2000 Limited
2000 Buick LeSabre Limited. I did a couple of quick searches but came up empty so need to ask a question. I have the bracket off and the wiring disconnected from the valve so the last item to remove is the vapor hose. How is the hose disconnected from the Vapor Canister Vent Solenoid?
PostPosted: Wed Dec 27, 2017 9:31 pm
These are the instructions for removal:
Raise the vehicle.
Bend the retaining tab of the EVAP canister vent valve.
Remove the valve from the bracket.
Disconnect the electrical connector from the EVAP canister vent valve.
Loosen the hose clamp and remove the hose from the EVAP vent valve.
Remove the EVAP canister vent valve from the vehicle.
PostPosted: Wed Dec 27, 2017 10:20 pm
OK but how do I disconnect the vent hose clamp. I have everything disconnected except for the hose and the hose has a type of plastic release clamp. The bracket is off the valve and off the car. If it were not for the hose clamp I would have it off the car. Is there a tool that is required to disengage the clamp or just technique? Thanks
PostPosted: Thu Dec 28, 2017 4:23 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
The clamp is simply squeezed to release it.
The same is true of the clamps at the purge valve.
There are no new unread posts for this topic. Attachment(s) vapor canister on 2000 SSEi
mrbul35
Sun Jun 26, 2011 11:28 am
brianj View the latest post
There are no new unread posts for this topic. rear drivers side floor wet everywhere else dry
swampthing
12
2637
Wed Jan 28, 2009 2:33 pm
There are no new unread posts for this topic. Fuel Vapor Vent valve removal question
Ken_W
16
4591
Tue Nov 06, 2012 7:33 pm
2002FO View the latest post
There are no new unread posts for this topic. Drivers side rear pillar plug...what is it?
ptrfair
Fri Jul 11, 2008 11:52 am
There are no new unread posts for this topic. P0420 and P0440 - Canster Purge or Canister Vent Soleniod?
IABeancounter
Tue Jul 12, 2011 1:26 pm
Archon View the latest post
