It is currently Sun Feb 17, 2019 5:34 pm
 Post subject: Coolant disappearing
PostPosted: Wed Dec 27, 2017 3:06 am
I have a 2000 SSEi and recently I started having an issue where it would overheat by like 5° and then the heat wouldn't work. But after a bit of driving it'd go back to normal. I had no idea why it couldn't seem to make up it's mind but being a broke college student I let it go. More recently it started actually overheating. One day going down the highway it jumped to 280° and I quickly pulled off. Come to find out it's super low in coolant so I dumped 2 gallons into it and bled some air out the thermostat nipple. Day later it overheats again. And I find the radiator practical empty again. I have no idea where it's leaking from, I had my mechanic replace a few major gaskets a while ago due to coolant leaks. Tomorrow if I can remember how, I'll attach a couple pics of where it was smoking from and also where it seems to be wet. It's right below the exhaust pipe from the front header where it goes over top the transmission.
 Post subject: Re: Coolant disappearing
PostPosted: Wed Dec 27, 2017 9:15 am
sounds like its in the throttle body area... look carefully around the thermostat - did you close the nipple?
start the car and fill coolant - bleed and you will see the leak once the system is pressurized.
PostPosted: Wed Dec 27, 2017 10:33 am
Yes nipple is closed. I will check the throttle body area when j get off work today. Is that a gasket that could be replaced myself? Or does it require a mechanic
PostPosted: Wed Dec 27, 2017 1:49 pm
if its just the tb, hose, egr , plenum, then no - you would need about a 5 out of 10 in skill and standard tools.
first you find the leak - see if its pooling and draining on the thermostat side or actually leaking from there.
PostPosted: Thu Dec 28, 2017 4:41 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
You really have to pinpoint it.
You can borrow a cooling system pressure tester for free for some parts stores.
This is how mechanics most often check for leaks.
With the system full, pressurize the system to no more than 15 lbs and see where coolant comes from.
There's also the engine coolant temp. sensor, the supercharger to LIM gasket, the side cover of the LIM and the LIM gasket itself as potential leak points.
An overheat that caused a 2 gallon coolant loss in a day shouldn't be difficult to see.
Check for coolant in the oil, since failed LIM gaskets can put coolant into parts of the engine where it doesn't belong.
The oil will look like a chocolate milkshake if there's coolant in it.
If this is the case, then the gasket must be changed without delay and the oil too before it ruins the bearings.
Don't keep driving the car, as the overheating can ruin the head gaskets, making for more repairs.
Hopefully, this has not already occurred.
PostPosted: Fri Dec 29, 2017 6:02 pm
Be mindful that there is a gasket/crossover between the engine and transmission that could be a possible culprit ( Andrew picked up a Bonneville for cheap because the repair was more than the car was worth to the owner. ) there's a small opening near the top of the transmission bell housing that you would want to look at for coolant, as well as seepage between the engine/transmission underneath.
This would be a worst case scenario. Don't rule out the Lower intake gasket though, even if they were replaced...as mentioned, a coolant pressure test in this case will prove invaluable.
There are no new unread posts for this topic. 3.8 supercharged coolant disappearing
94BONNE
Sat Nov 27, 2010 11:04 am
willwren View the latest post
There are no new unread posts for this topic. Coolant is gone...254 degrees, cracked coolant elbow!
Ludichris
23
2420
Thu Oct 25, 2012 2:04 pm
PLAGUE PHANTOM View the latest post
There are no new unread posts for this topic. Oil in Coolant
bschoole
14
3187
Fri Oct 08, 2010 3:33 pm
bschoole View the latest post
There are no new unread posts for this topic. Oil in coolant
gb2105
Mon Jan 25, 2016 9:13 pm
gb2105 View the latest post
There are no new unread posts for this topic. Coolant?
irish91983
Tue Mar 01, 2011 11:22 pm
Users browsing this forum: No registered users and 14 guests
