It is currently Mon May 21, 2018 3:17 am
 Post subject: P0420 code ??? Help
PostPosted: Wed Dec 06, 2017 7:38 pm
Year and Trim: 2000 Lesabre
CEL came on today, scanner says above code,,,car has 195k on it...how do I know IF its the convertor or the 02 sensor ??
Thx
 Post subject: Re: P0420 code ??? Help
PostPosted: Thu Dec 07, 2017 10:05 am
if you have a scanner that reads rediness, you can see if the o2 sensor passed its self-diagnostic. if it did, sensor is ok but still could be many causes
look here....http://www.easterncatalytic.com/educati ... 420-codes/
PostPosted: Thu Dec 07, 2017 1:41 pm
After 195k miles, it's probably the cat.
"Penelope" - 2003 SLE - 172k Miles
2000 Honda S2000 - 52k miles
PostPosted: Tue Dec 12, 2017 12:30 am
Year and Trim: '03 SLE Silver/Charcoal
I am at 183k and mine is doing this as well. I use Torque Pro to log the data and check readiness. I can clear it and it comes back... Cat is not clogged so I am running it as it is for now as we do not smog check and if they do they just look for codes... delete in the parking lot and pray it don't flag when tested when we did have testing here. I will eventually get it replaced when it warms up. and I replace the exhaust system...
2002 SLE "Frankenbonnie" 02 engine, 04 transmission, and a 03 PCM to make everything talk. Sadly I know longer own
1993 Suburban Zombie Apocalypse Assault Vehicle (GMC Edition)
2003 Yukon Black/Charcoal cloth 4x4 POW/MIA
2003 SLE Silver/Charcoal (New Acquisition)
PostPosted: Mon Dec 18, 2017 9:00 pm
I did the spark plug non fouler mod to the rear 02 sensor,,,light has been off for almost 200 miles :banana:
There are no new unread posts for this topic. P0420 code fixed now (new cat) now p1441 code
gold8165
Sat Jun 25, 2011 4:14 pm
mrbul35 View the latest post
There are no new unread posts for this topic. CODE P0420
bonnieandclyde
Sat Dec 10, 2011 5:25 pm
bonnieandclyde View the latest post
There are no new unread posts for this topic. Code P0420
SSEI173
Wed Feb 13, 2013 7:49 pm
SSEI173 View the latest post
There are no new unread posts for this topic. The dreaded P0420 code
Togemachi
Tue Oct 11, 2011 9:52 pm
This topic is locked, you cannot edit posts or make further replies. The dreaded P0420 code
Togemachi
Tue Oct 11, 2011 10:04 pm
Gumball View the latest post
