It is currently Tue Apr 16, 2024 1:40 pm
 Post subject: Heater/Ac Blower 2002 SE
PostPosted: Wed Dec 06, 2017 12:22 am
I replaced the pigtail going to the blower, thinking that was the problem of no blower fan . I have to wiggle the pigtail til the blower starts. I also keep blowing fuses. Any Ideas?
PostPosted: Wed Dec 06, 2017 12:56 am
wiggle? if you wiggle wires, your splice job was buget -redo and put tape on all connections so they dont touch each other.
what was wrong with the original connector?
PostPosted: Wed Dec 06, 2017 11:50 am
Your original issue was probably caused by worn brushes in the fan motor itself. Replace the motor.
"Penelope" - 2003 SLE - 247k Miles
"Sydney" - 2000 Honda S2000 - 98k miles
PostPosted: Wed Dec 06, 2017 12:20 pm
That's probably it. The old pigtail was cobbled up to try to make the fan work. I replaced the pigtail, and it worked fine, as long as you would slightly move the plug side just a little. Now it won't work at all, after three days. The fuse is ok. I re-wired the pigtail with heat shrink barrel connectors that came with the part.
PostPosted: Tue Dec 12, 2017 12:33 am
Year and Trim: '03 SLE Silver/Charcoal
very well could be the connector that the pigtail is plugging into if you had to move it to the side to get it to work sounds like a cold or broken solder joint. could you fix it maybe, but probably more economical in time and frustration in replacing the fan assembly
2002 SLE "Frankenbonnie" 02 engine, 04 transmission, and a 03 PCM to make everything talk. Sadly I know longer own
1993 Suburban Zombie Apocalypse Assault Vehicle (GMC Edition)
2003 Yukon Black/Charcoal cloth 4x4 POW/MIA
2003 SLE Silver/Charcoal (New Acquisition)
There are no new unread posts for this topic. heater/blower help
brocker11
Sat Mar 01, 2014 10:29 am
brocker11 View the latest post
There are no new unread posts for this topic. heater blower fan
gold8165
Thu Jul 05, 2012 11:16 am
Petermcmxii View the latest post
There are no new unread posts for this topic. heater blower motor
jetrcmsp
Tue Sep 09, 2014 2:01 pm
SteveNC7 View the latest post
There are no new unread posts for this topic. Needed: Know how for heater blower fan replacement
SuperSLE
Tue Jun 03, 2008 9:51 pm
SuperSLE View the latest post
There are no new unread posts for this topic. Heater blower, duct work question
bopguy
Fri Oct 19, 2012 9:37 pm
bopguy View the latest post
