It is currently Mon Jan 21, 2019 1:37 pm
PostPosted: Mon Nov 20, 2017 12:04 pm
Year and Trim: 2001 SE
While driving yesterday, my pressure gauge suddenly went to 0. The car seemed to be working fine. Got a check gauges message. After a couple of minutes, indicator started climbing to about 60 and then went back down to around 38. My shop says I need an Oil Pressure Gauge Switch which is thirty some dollars from Advance with discount. Does this seem right? Rockauto doesn't have the part at all and Advance makes a Driveworks for 37, a BWD for 42, and a Wells for 72. Advice?
PostPosted: Mon Nov 20, 2017 12:15 pm
Yes, super common problem. Replace the switch next time you do an oil change. The sensor is directly above the oil filter and some oil will come out when you remove it.
FYI, Rockauto does carry them, they have 4 options. Electrical-Switch & Relay -> Oil Pressure Sender / Switch
-Andrew-
PostPosted: Mon Nov 20, 2017 1:26 pm
Thanks. But I still can't see it in RockAuto. Looked under Electrical Switch and Relay but the only thing under oil pressure is the oil pressure switch socket tool.
PostPosted: Mon Nov 20, 2017 1:34 pm
Online
Year and Trim: 2000 SLE 2005 SLE
1975 Monte Carlo
I buy my switches from Auto Zone.
They have a life time guaranty.
I have replaced 3 or 4 in the last 6-8 years on my two Bonnevilles.
I just take in the defective one and they give me a new one.
This is a common problem on these cars.
I use a deep 27mm socket to take it off.
PostPosted: Mon Nov 20, 2017 3:21 pm
Thanks. Will do.
PostPosted: Mon Nov 20, 2017 6:20 pm
Quote:
Pontiac -> 2001 -> Bonneville -> 3.8L V6 -> Electrical-Switch & Relay -> Oil Pressure Sender/Switch
If you can't figure out how to get there on RockAuto, just search the part numbers
-Andrew-
There are no new unread posts for this topic. Erratic Oil Pressure Gauge
02 Bonnie
Thu Jan 19, 2017 5:26 pm
ddalder View the latest post
There are no new unread posts for this topic. Fuel gauge erratic : check gages light still comes low fuel
MrPOPE
Fri May 16, 2014 10:02 am
MrPOPE View the latest post
There are no new unread posts for this topic. oil pressure gauge
mfcordova2008
Tue Feb 15, 2011 2:27 am
There are no new unread posts for this topic. Oil pressure gauge
turbomrk
Tue Feb 15, 2011 10:15 pm
turbomrk View the latest post
There are no new unread posts for this topic. Oil Pressure gauge
robjr69
Sat Apr 23, 2011 11:38 am
MiDMoTSI View the latest post
Users browsing this forum: agrazela and 8 guests
