It is currently Thu Feb 21, 2019 2:32 pm
 Post subject: Pulley barring squeek?
PostPosted: Tue Oct 24, 2017 2:42 pm
RIP 2001 SSEi
I have a 2000 SSEi -edit
Hey guys just noticed this noise a few days ago thats started to develop, at first I thought it was a belt squeak but im convinced its not. It seems to be coming from one of the pulleys and could not locate it with a mechanics stethoscope. Im kinda stumped. Has anyone had a baring go bad in one of their pulleys? Also it does seem to get louder with throttle. tested this at a drive through. It gets louder the more throttle but then gets drown out by the exhaust pretty soon so I would think I can rule out any accessory stuff. Maybe the super charger baring has gone bad. Any ideas guys?
Bonnie - 2001 Bonneville SSEi RIP in spaghetti never forgetti
Goldein - 2000 Bonneville SSEi Live forever.
2.25" I/C, Machined LIM, 42.5 Injectors, 3.0 S/C Pulley, 72mm TB, SD Headers+ZZP DP+magnaflow Catback, ZZP tune.
PostPosted: Tue Oct 24, 2017 7:53 pm
Year and Trim: '03 SLE Silver/Charcoal
on several of my GM's I have had to replace the idler gear... matter of fact I keep one onhand just in case.
2002 SLE "Frankenbonnie" 02 engine, 04 transmission, and a 03 PCM to make everything talk. Sadly I know longer own
1993 Suburban Zombie Apocalypse Assault Vehicle (GMC Edition)
2003 Yukon Black/Charcoal cloth 4x4 POW/MIA
2003 SLE Silver/Charcoal (New Acquisition)
PostPosted: Wed Oct 25, 2017 3:52 am
RIP 2001 SSEi
Does the ilder gear going bad sound like what I described?
PostPosted: Wed Oct 25, 2017 9:28 am
Have you tried pulling the belts and turning the individual pulleys by hand?
PostPosted: Wed Oct 25, 2017 3:04 pm
RIP 2001 SSEi
I have thought about it, but I was going to wait for the weekend to delve into it. I started looking more into it on youtube, found a few people with the same noise I have the the first guy might be right. Some say its just the throttle idle pulley or the tensioner going bad, they are the same size and same pulley. And some say it was the barring for them. So I just bought 2 pulleys and am gonna replace the idle and tensioner and see if that fixes it. They looked old and the pulleys wernt to much that If it is a baring I wont feel bad about changing them out for new.
PostPosted: Wed Oct 25, 2017 4:37 pm
if the belts looks questionable might as well change it too since you are going to remove it. Also start the car (briefly) with the belt removed to confirm the noise is coming from a belt driven accessory or supercharger
PostPosted: Wed Oct 25, 2017 6:00 pm
I was gonna say, remove the belts. I spent a year one night bouncing between 3 parts store parking lots replacing pulleys, it ended up being the lower idler for the belt, it was the last one I replaced, and that was after I replaced the entire tensioner because I thought it was bad. I think I still have a spare ribbed pulley from that incident, 5 years ago. I replaced all of them before I figured that one was bad, I finally saw it dancing around. In my defense, it was February and cold, and I had to fix it so it was reliable for my 2 hr drive to the airport the next day...
PostPosted: Thu Oct 26, 2017 3:32 am
RIP 2001 SSEi
I really appreciate the tips you guys are sending my way. I will definitely check the belt and the other pulleys while the belt is off. make sure none of them are wobbly or anything. I will do it this weekend, If the pulleys arrive by then (I hope) This is the first actual mechanical thing I've had to fix on this car in all the miles I've put on her.
PostPosted: Sat Nov 04, 2017 10:19 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
As bearings go bad, they may just feel rough when you turn them by hand, rather than there being too much play.
I changed out all the pulleys and belts with good quality replacements from Rockauto and Amazon when I first got my cars.
Not worth getting stuck on the side of the road due to a $12 pulley or $20 belt.
PostPosted: Mon Nov 13, 2017 12:09 am
RIP 2001 SSEi
True that, I found that the tentioner and the idler were both bad, So I replaced both and both belts with high quality replacements, now Goldein is a happy camper.
PostPosted: Mon Nov 13, 2017 5:44 pm
1998 SE
2001 SSEI
2002 SSEI
...and now, Sether must be a happier camper , too!
Always nice when it's a simple & relatively inexpensive fix.
PostPosted: Tue Nov 14, 2017 6:18 am
RIP 2001 SSEi
You are right! No longer stressing about the problem and that gives me more time thinking about what performance/general upgrades I want to do next, Like a smaller SC pulley or maybe a new transmission pan with an actual drain plug and a shift kit. These are the things I'd rather be thinking about. :D
There are no new unread posts for this topic. Strange squeel/squeek after Intake Manifold Gsket replace.
dandyd
Tue Dec 27, 2011 9:56 pm
dandyd View the latest post
There are no new unread posts for this topic. 3.4 Pulley and no KR??
305RSlc
Wed Oct 02, 2013 11:41 am
gweg_b View the latest post
There are no new unread posts for this topic. AC Pulley
quicksilver
Fri Mar 11, 2011 11:58 pm
sm in Georgia View the latest post
There are no new unread posts for this topic. pulley pullers...
LAIDBACKLUKE
Sun Oct 30, 2011 10:54 pm
LAIDBACKLUKE View the latest post
There are no new unread posts for this topic. Squeeky Pulley
grandprix104
24
2327
Wed Jul 22, 2009 5:59 pm
Grimm View the latest post
cron
