It is currently Sun Feb 17, 2019 6:19 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Tue Oct 17, 2017 9:23 am
Morning,
Today I hit a pothole on my dirt road with my passenger side front wheel. At that moment, both the "Trac off" and "Anti-Lock" lights came on and are staying on.
What the hell did I do now?
PostPosted: Tue Oct 17, 2017 1:49 pm
it may be the wheel speed sensor that is in the bearing/hub assembly.
with the jarring, it may have come unplugged or damaged
PostPosted: Tue Oct 17, 2017 10:26 pm
You will need to replace that wheel bearing. Not a terrible job. I recommend Timken as the replacement.
I had this same issue with my car but with the rear driver wheel.
PostPosted: Wed Oct 18, 2017 9:19 am
99% sure you'll end up with a wiring issue, not a hub replacement.
-Andrew-
PostPosted: Wed Oct 18, 2017 2:23 pm
I have had a bad wheel bearing for a while now (same wheel that hit pot hole). I'll have to replace them soon.
Hopefully this issue goes away and I don't have a wiring issue...
PostPosted: Thu Oct 19, 2017 8:08 am
I’m the type of person who likes to know the “whys” when something fails. So this is what happened over the week.
On Monday, trac off and anti-lock lights still on, I pulled into gas station. Pumped my fuel and started the car. Trac off and anti-lock lights were off!
As I pulled out of station they both came back on.
Then today, I did same thing. I pumped fuel, started car and they both were off!
As I pulled out they came on!
Is it possible the weight from the fuel is triggering something in the rear?
PostPosted: Thu Oct 19, 2017 9:00 am
Get your codes scanned before even thinking about trying to guess what is going on.
-Andrew-
PostPosted: Thu Oct 19, 2017 12:13 pm
Andrew,
I don't have any check engine lights on. Will there still be codes?
PostPosted: Fri Oct 20, 2017 4:34 am
57j2olds wrote:
Andrew,
if you have body codes, that doesn't light the cel. CEL is primarily for emissions. plus, the scan will tell you which wheel is bad - I would do the bearing and see if its the issue - needs to be done anyway.
PostPosted: Fri Oct 20, 2017 9:47 am
A Tech2 scanner will find your culprit without firing the parts cannon at the car.
PostPosted: Sun Oct 22, 2017 7:49 pm
Ok so I replaced both front wheel bearings. Passenger side wires were cut. However....I still have Trac and antilock lights on.
Do they need to be cleared with scan tool?
PostPosted: Sun Oct 22, 2017 10:55 pm
Did you fix the wiring? The lights don't need a reset.
PostPosted: Mon Oct 23, 2017 8:19 am
Hello,
The cut wires were between the hub and the hub connector so once new hub was installed had new connector.
I'm at a loss.
Wondering if I should turn key to run position, then pull wheels off and mess with connectors to see if I can get a connection by trying to get dash lights to go off.
PostPosted: Mon Oct 23, 2017 9:32 am
Get an ABS scantool on there and quit guessing.
-Andrew-
PostPosted: Mon Oct 23, 2017 10:11 am
I wish I could afford that.
PostPosted: Mon Oct 23, 2017 4:13 pm
One thing I didn't do yet was check the rear connectors.
If it ever stops raining here I'll try that.
PostPosted: Mon Oct 23, 2017 8:50 pm
Check around. Some Advance Auto, and Autozones have ABS scanners that they can use to scan your car.
PostPosted: Mon Oct 23, 2017 9:24 pm
you try to disconnect the battery. maybe it'll reset.
does the trac control work?easy to test.
put some sand in a park lot and see if abs works also - maybe the light is funky
PostPosted: Tue Oct 24, 2017 8:57 am
Cool thanks. I will call around.
PostPosted: Tue Oct 24, 2017 1:19 pm
OK its the right front wheel speed sensor. I just had it scanned.
What do I start first?
Is that passenger side?
There are no new unread posts for this topic. Trac Off and Anti-Lock Issue
57j2olds
Wed Aug 01, 2018 9:05 am
57j2olds View the latest post
There are no new unread posts for this topic. Trac Off and Anti-lock lights are on
masher
Tue Dec 21, 2010 1:08 pm
There are no new unread posts for this topic. Brake / Anti Lock / Trac Off Lights!!!
chisox.fan
14
2819
Mon Aug 12, 2013 8:09 pm
chisox.fan View the latest post
There are no new unread posts for this topic. 'Trac Off' and 'Anti Lock' dash lights
hawkjet
Wed Oct 22, 2008 2:24 pm
hawkjet View the latest post
There are no new unread posts for this topic. sluggish takeoff when anti-lock/trac off light is on
2000GreySSEi
Thu Feb 10, 2011 3:20 pm
2000GreySSEi View the latest post
