It is currently Fri Jun 22, 2018 3:01 pm
PostPosted: Sun Jun 18, 2017 4:47 pm
Year and Trim: 2005 Pontiac Grand Prix GTP - 205,000 km
It's been years since I've posted here but this place seems more active then any Grand Prix forums and the Bonneville guys were always more knowledgeable anyways sooooo...(and just so you know I had an 89 Bonneville SSE and 96 Bonneville SSEi before I switched to Grand Prixs, and I only did because I couldn't find any decent Bonnevilles around here anymore ;) )
I currently have a '05 Grand Prix GTP with 205,000 km with pretty much zero problems till recently. Every so often (few times a week?) when I accelerate from a dead stop, there will be a thud that feels like car just changed gears really badly. Everything else about the trans is great. 1-2, 2-3, 3-4 and OD all operate smooth as butter. Goes into drive and reverse with zero issue. Shift at WOT absolutely perfect. Just for fun I dropped the pan this weekend. Nothing unusual, no metal chunks, a bit of clutch material on the magnet. The fluid was dark but didn't smell burnt at all. I changed the fluid and filter, threw in a transgo shift kit and put it back together. It now shifts even more perfect, downshift response is fantastic, but still....every so often from a dead stop I get this clunky thud that feels like a bad gear change. Do I have anything left to try other than replace/rebuild the transmission? The car is otherwise perfect and it would be sad if this was the beginning of the end.
Thanks for any help
2005 Pontiac Grand Prix GTP Competition Group - 43, 000km - L32 3800 - 3.29 Final Gear Ratio - RETIRED
1996 Pontiac Bonneville SSEi - 203, 000km- L67 3800 - 2.93 Final Gear Ratio - RETIRED
1989 Pontiac Bonneville SSE - 222, 000KM - LN3 3800 - 2.97 Final Gear Ratio - RETIRED
PostPosted: Mon Jun 19, 2017 2:44 pm
Year and Trim: 2000 SSEI
I wonder if there is something in the TQ converter letting lose... idk if you have access to a TECHII or something to scan the trans, sometimes shift solenoids go bad. does it rev or slip before it bangs into gear and move?
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Mon Jun 19, 2017 4:53 pm
This is called delayed engagement, and there isn't much you can do about it with the transmission in the car. My car has had this issue come and go for years. In my case it seems to be depend on the ambient temps. Anyways, you can read about it here under common problem #2:
http://www.gmls4.com/index.php?topic=2773.0
"Penelope" - 2003 SLE - 173k Miles
"Sydney" - 2000 Honda S2000 - 53k miles
PostPosted: Mon Jun 19, 2017 9:30 pm
Thanks for the replies! It doesn't rev or slip before it goes into gear, just a big thud and off she goes. I have pulled the max adapt/long shift code before which is one of the reasons I installed the shift kit.
The delayed engagement described in that link sounds exactly like what I'm experiencing. I don't think I'm going to tear into the transmission at this point, but it sounds like you can drive a long time like this without issue. I'd say for me it almost always happens when the car has been heatsoaked sitting in traffic on a hot day.
PostPosted: Tue Jun 20, 2017 3:38 pm
Install a trans cooler!
There are no new unread posts for this topic. Will a 97 gtp 4t65-hd trans fit a 00 ssei
2000GreySSEi
Sun May 08, 2011 5:51 pm
There are no new unread posts for this topic. Trans Issue or Ignition/Fueling Issue(s)
WhiteArrow3800
15
1337
Wed Aug 26, 2009 11:11 pm
There are no new unread posts for this topic. Grand Prix Radio
J-ROD
Thu Dec 18, 2008 5:06 pm
There are no new unread posts for this topic. '98 Grand Prix Misfire (Cylinder 5)
yonkerse
Tue Dec 20, 2011 2:24 pm
yonkerse View the latest post
There are no new unread posts for this topic. Grand Prix Headers on SSEI??
3800Charged
Sat Feb 09, 2013 3:11 pm
3800Charged View the latest post
