It is currently Wed Feb 20, 2019 10:33 pm
 Post subject: 2001 v 1996 MAF
PostPosted: Thu Sep 22, 2016 11:44 pm
Year and Trim: 2001 SSEi
Can I use a MAF from a 1996 Bonneville 3800 on my 2001 SSEi 3800?
Part numbers (AUTOZONE) are 2001 – DL-3011, 1996 – DL-3012
The screw holes and plug both line up, look identical EXCEPT the 1996 has a shorter plastic piece that goes into the intake vs the 2001.
Now the 2001 SE and SSEi share a MAF so the supercharger is not a factor from what I can tell.
I’m thinking it’s a thing where the 96 will work on both but the 2001 will only work on the 2001.
 Post subject: Re: 2001 v 1996 MAF
PostPosted: Thu Sep 22, 2016 11:47 pm
You'd probably want to measure resistances between the 2 to know for sure, but usually MAF design is changed mostly due to improvements for airflow, or integration ( such as a bolt on MAF vs an inline version that is held in place with band clamps.
PostPosted: Thu Sep 22, 2016 11:58 pm
how do i measure resistance?
PostPosted: Fri Sep 23, 2016 7:14 am
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Sorry, I don't know the answer to your question, but the MAF sensor generates a signal so I don't think that you can measure resistance to compare
PostPosted: Fri Sep 23, 2016 11:14 am
NO, you cant. the holes line up fine but the wires that get the reading are too short: the 200+ have a much longer stalk to put the wires in the centre of TB. the reading wont be accurate.
I already tried and it didnt work- got po300 codes
put a used delco in and all is good
PostPosted: Fri Sep 23, 2016 6:50 pm
I put 96 MAF in my 2001. No problems, hard to tell if it runs any different but no codes or anything.
The stalk on the 2001 was longer, but the metal filament thing is in the same location.
Now the 2001 may not fit in the 96 due to stalk size, however the 96 is working in the 2001.
PostPosted: Mon Sep 26, 2016 3:22 pm
I would not do that... The frequency range between the( 96-98 ) AFH50M-04 is different than the 99-05( AFH50M-05 )..
For anyone reading this, Please Do Not use a 96 MAF on a 99-05..
PostPosted: Mon Sep 26, 2016 10:01 pm
I wasn't able to find the specs on the MAFs.
What are the differences between them and what could result from using the wrong one?
Since i swapped mine,
I haven't driven the car with any major significance. (maybe 10-15 miles)
Currently I don't really see a difference (maybe it appears slightly more responsive, could be psychological though since I'm looking for an improvement...)
No codes have been thrown, I asked a mechanic prior to attempting this and he said it wouldn't run if it didn't work.
Thanks
There are no new unread posts for this topic. 1996 Bonne Fixed Finally!!!
NatiBigDaddy
Thu Jul 20, 2017 10:38 pm
NatiBigDaddy View the latest post
There are no new unread posts for this topic. 2001 ssei
mike.303
Sat Nov 14, 2015 5:57 pm
There are no new unread posts for this topic. 2001 3.8 free
farmermike
Fri Sep 22, 2017 1:24 am
Ishkabod View the latest post
There are no new unread posts for this topic. Need help on 2001 not cranking
justin_h635
Wed Jun 29, 2016 11:18 am
There are no new unread posts for this topic. Help with my 2001 bonneville
daddy-o
21
10736
Mon Sep 20, 2010 5:52 am
daddy-o View the latest post
Users browsing this forum: Google [Bot] and 9 guests
