It is currently Thu Jul 18, 2019 4:14 pm
 Post subject: 2000 Bonne AC Problem
PostPosted: Thu Nov 05, 2015 8:56 pm
Year and Trim: '91 Olds 98 Regency Elite
'88 Bonneville
My daughter has a 2000 Bonne (VIN K)....AC had been working just great.....then today she comes home and the windows all fogged up in the rain/humidity of the day. I discovered the AC Compressor was not functioning.....I started looking for the low pressure switch which is normally near the Receiver/Dryer but being dark I could not locate it..... I wanted to jump the terminals just to see if the compessor would kick on for a few seconds (Save me the time to check wiring in the dark...etc...) I could not find the switch..... I do see the High Pressure Switch attached to the high side near the compressor, but could not find the low side switch...... Where is that switch so when it gets light in the morning, I can find it quickly???
PostPosted: Mon Nov 09, 2015 12:04 pm
Year and Trim: 2001 SSEi
Don't know how accurate this is, but here's what the Advanced Auto Parts website says (two answers): A: The air switch is located under dash on passenger side on the side kick plate.
Answered on 4/12/2011 by David the Dynamite Parts Guy from AAP
A: On the high pressure line between the fire wall on the passenger side under the hood and the "receiver and dehydrator assembly", below the larger diameter low pressure line running toward the radiator. It is screwed into a schrader valve and can be taken out - without vacing the CF134a. It has a three pin connector.
PostPosted: Tue Nov 10, 2015 10:16 am
'88 Bonneville
Found the problem without the switch.....the magnetic coil pick up behind the compressor clutch has gone bad.
There are no new unread posts for this topic. Valve Tap..... 2000 Bonne VIN K
dandyd
Tue Jan 13, 2015 12:04 am
dandyd View the latest post
There are no new unread posts for this topic. 2000 bonne possible sc belt issue.
JEzze
17
2065
Mon Feb 20, 2012 1:51 pm
There are no new unread posts for this topic. 2000 bonne trans issue, please help!
pontiacfreak142
Wed Sep 24, 2014 7:36 am
pontiacfreak142 View the latest post
There are no new unread posts for this topic. Attachment(s) 2000 Bonne Climate Control Issue
dandyd
11
1262
Tue Apr 07, 2015 8:44 am
There are no new unread posts for this topic. 2000 SLE Sunroof Problem
Spl170s
Wed Jul 30, 2008 9:48 am
Spl170s View the latest post
Users browsing this forum: JohnR and 18 guests
