It is currently Wed Jan 23, 2019 2:15 pm
PostPosted: Sat Oct 24, 2015 7:06 pm
I feel the symptoms but need confirmation that the problem is internal to the transmission and not some external device.
The TC locks up and does not release until the engine almost stalls when coming to a stop, then it releases, starts out fine in 1st then after banging into second locks the converter and it remains locked when shifting into 3rd....holy neck snap!
Not good I know.
When the input piston began to slip last month when cold, I fixed it....temporarily it seems......by installing a transmission pressure modulator and increasing the pressure enough to stop the slipping. It never thru a code the whole time it was cold slipping.
Now with this new problem, it throws the P0742 code. I cleared it twice and it drove fine for a few minutes then clunk it lit up again.
*dang* and I just installed brand new performance tires!
For Sale
$5,000. Canadian $4,000 USD AS IS WHERE IS
There are no new unread posts for this topic. buck when shift..Torque Converter Clutch Circuit Stuck On??
kp8420
Sun Sep 14, 2008 10:43 pm
Archon View the latest post
There are no new unread posts for this topic. p0480 fan 1 control circuit
assumedruz
Sat Jan 26, 2013 1:26 am
There are no new unread posts for this topic. P0404: EGR Circuit Range/Performance
Sat Aug 13, 2011 3:48 pm
There are no new unread posts for this topic. P0102: Mass Air Flow Circuit Low Input
umbrau44
Tue Dec 07, 2010 1:26 am
umbrau44 View the latest post
There are no new unread posts for this topic. P0341 Camshaft Position Sensor Circuit Range/PerformanceHELP
chus007
Fri Aug 19, 2011 7:39 am
chus007 View the latest post
Users browsing this forum: Google [Bot] and 9 guests
