It is currently Fri Jul 10, 2020 8:07 am
PostPosted: Mon Sep 21, 2015 10:47 pm
Year and Trim: 2001 SSEi
I posted that my left rear door was not communicating with the rest of the car. It was suggested that a wire was broken in the "accordian" wire cover that goes from the B pillar to the back door. I did not find a damaged wire.
Today, my front passenger door became non-communicative! I unlocked my front passenger door with the key, the unlock switch to open all of the doors would not work, so I reached into the back seat and unlocked that door and opened it and the alarm went off. Opening and closing the front passenger door does not make the lights come on. Even the driver's door controls won't make that window go down (that's still the case with the rear driver's side door too. Also, occasionally when I put the key in and turn it, absolutely nothing happens. I get out cuss at it, kick it a few times and then try again and it usually starts and run perfectly.
When it's acting up, turning the key won't even turn the radio on.
Please help! I don't have any confidence in this car right now. I have no idea when I'll be stranded in the middle of nowhere and even though I always have tools in the trunk, I would have no idea where to start!
Thanks,
PostPosted: Tue Sep 22, 2015 8:06 am
Hi, when I let my drivers door module get wet, the car acted similar so I would suspect the main control mod on drivers door.But I didn't have the ignition issues you speak of. Do the seat presets on door and mirrors work? As for the key, have you tried the spare?.......... keep smiling
PostPosted: Tue Sep 22, 2015 2:48 pm
This is a duplicate thread to this one... 2000-2005-other-than-gxp/topic47001.html
PostPosted: Tue Sep 22, 2015 3:42 pm
Yeah, I've had to replace that driver's side module once before. The seat and mirror memory are working, so I'm pretty sure it's not that.
Others have posted the corroded wiring connector under the driver's seat, and I've had some problems with clogged A/C condenser drain, so I've had a wet floor for awhile, so I'm sure I need to correct that wiring.
Thanks for the help.
Sorry for a duplicate thread.
When I tried to post last night, I got an error message, so I posted it again and later on the first post showed up also.
There are no new unread posts for this topic. ssei door window problems!
hughjhas
Tue Oct 08, 2013 10:57 am
There are no new unread posts for this topic. 01 SSEi Door/window problems -FIXED
Oldman
Thu Oct 22, 2015 10:59 pm
ddalder View the latest post
There are no new unread posts for this topic. 2000 SSEi window problems! [FIXED]
00V8
Fri Jan 01, 2016 11:49 pm
MKMike View the latest post
There are no new unread posts for this topic. 2002 ssei door lock and window problem.
flopo
Sun Aug 05, 2012 6:32 pm
flopo View the latest post
There are no new unread posts for this topic. Window problems
Bichselmnop
Wed Sep 17, 2008 11:14 pm
Users browsing this forum: No registered users and 15 guests
