It is currently Fri Jul 10, 2020 8:29 am
PostPosted: Wed May 27, 2015 12:25 pm
It was bound to happen sooner or later.....
It only happens after a dead cold start when accelerating from a stop in first gear turning left, not right.
It doesn't display any symptoms after the first take off.
It makes a machine gun like jerking and groaning noise that increases with throttle. I go easy and it will decrease the jerking, grab and slowly go.
I thought it might be the limited slip but not sure.
So is this the beginning of the clutches going south? Is it rebuild time?
PostPosted: Wed May 27, 2015 1:28 pm
Year and Trim: 2003 Bonneville SSEi.
4T65e (unless modified) doesn't have a limited slip. Likely your forward band is starting to go or you should change the PCS
PostPosted: Wed May 27, 2015 8:58 pm
Aftermarket LSD
Is it a normal symptom of a forward band going? Never had it happen before.
Why would the PCS only do that cold on a left hand turn?
PostPosted: Thu May 28, 2015 1:18 am
Spoke to my father about this. He says that since you have a LSD final drive to check it and possibly replace it.
I first thought it to be a band because a transmission can shudder when taking off. But you said it only happens when you turn.
PostPosted: Thu May 28, 2015 11:55 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Perhaps it's a failing cv joint(s)?
A bad CV will definitely make a sound like a machine gun while making a turn.
The car may be struggling to overcome the resistance of the bad cv, hence the jerking.
Counterintuitively, the right outer joint is what causes noise when making a left turn.
Failing inner cv joints cause vibration/shudder on acceleration.
Have someone else drive and stick your head out the window while turning.
You should then quite clearly hear it.
I would also check the bearing/hub assembly , since it may be a compound problem rather than a single failed part.
Here's some more info http://classic.artsautomotive.com/axle_story.htm
PostPosted: Thu May 28, 2015 12:08 pm
Thanks, I'll do some experimenting.
Back in 2005 while drag racing, one of the right side boots spewed out all the grease. The grease was replaced under warranty and I haven't thought about it since.
But I did have to drive it 1000 miles before the grease was replaced....... :bhuh:
PostPosted: Thu May 28, 2015 4:30 pm
I turned right this morning so nothing happened.......but a few miles later after stopping and then starting, it seemed to slip and bang into gear while in drive. I was babying it so it didn't slam hard .......maybe the pressure control is messing up?? #-o
Going out now to do some more experimenting....driving in circles left and right......ttyl
PostPosted: Thu May 28, 2015 5:05 pm
1998 SE
2001 SSEI
2002 SSEI
Well the right axle would be cheap enough, if it's the problem. Cardone makes new axles that are inexpensive but good quality . https://www.cardone.com/find-parts/vehicle-parts-listing?make=Pontiac&model=Bonneville&year=2002
PostPosted: Thu May 28, 2015 6:02 pm
I'll start a new topic in September.
Transmission rebuild.
I can't complain. It was bound to wear out after 15 years of 13 second blasts to 150 mph lol.
And after SEVEN Bonneville Meets!!
Now to start saving up $3000. Ouch!
PostPosted: Thu May 28, 2015 8:54 pm
Banging after a stop sounds similar to the problem I had with my transmission before I went through it last. But mine then had 1,2&4 gears. And it would bang like you say. The valve that resides below the PCS in the valve body got hung up and made mine quit completely. I had to get another valve body (was from wrecking yard) and third input housing. Put the shift kit in it as well. Runs fine and has all gears.
Best way to check your LSD is raise the passenger side of the vehicle and take everything loose to access the cover for final drive.
Hope this helps.
PostPosted: Thu May 28, 2015 9:26 pm
It's all coming apart....maybe a good time to convert to a 3.69 gearset...... :bhuh:
PostPosted: Thu May 28, 2015 10:24 pm
1998 SE
2001 SSEI
2002 SSEI
At least you've figured it out and it isn't your sole mode of transportation.
Hope all goes well with the rebuild.
PostPosted: Fri Jun 05, 2015 10:11 am
Well I'm not totally convinced yet I've been driving it every day and it only does it for the first five minutes on initial warm up once it's warm there's no problem runs like a scalded cat but when it's cold and I take off from a start it slips and stutters and then grab suddenly and then's fine after that
Once warm the transmission temperature never goes over 170
It almost feels like the antilock brakes are coming on and then releasing
No codes. I haven't changed the fluid in a while I wonder if that could be a problem
PostPosted: Fri Jun 05, 2015 10:13 am
If it truly is the transmission then I have a decision to make
Repair for 3000 or sell for 6000
PostPosted: Tue Jun 09, 2015 11:28 am
So I've been researching and watching videos on the 4T65E-HD transmission. Piece of crap before 03!!
Who said Chrysler made bad transmissions?
To rebuild GM transmission properly will cost a lot more than $3K!
....and it also needs new tires ...
Anyone want to buy it as is for $5K? ($4K US)
I'll make my final decision in August..... :sucks:
PostPosted: Tue Jun 09, 2015 1:26 pm
Before giving up, give this a try. It worked a few years back on my daughter's Grand Prix that would slip when cold.
Add a can of Seafoam's Trans Tune and run that for a couple of weeks. Then, drop the pan and replace the filter and fluid. See if it helps. Cheaper than a rebuild.
There are no new unread posts for this topic. Strange pulsing vibration at 3k rpm
BobsBonneville
11
1310
Sun Sep 23, 2012 6:58 pm
BobsBonneville View the latest post
There are no new unread posts for this topic. Horrible engine vibration, strange smell from exhaust
bschoole
Thu Jul 07, 2011 3:00 pm
bschoole View the latest post
There are no new unread posts for this topic. Bad PCS? Transmission Slipping
pinstriper38
Thu Oct 15, 2015 8:26 pm
pinstriper38 View the latest post
There are no new unread posts for this topic. slipping transmission
wiro01sle
Wed Jan 05, 2011 11:47 am
There are no new unread posts for this topic. transmission slipping at high rpm?
BrianT
Tue Mar 24, 2015 8:10 am
