It is currently Wed Feb 20, 2019 9:09 am
Post new topic Reply to topic  [ 15 posts ]
PostPosted: Thu Apr 30, 2015 5:17 pm
Year and Trim: 2001 SSEi
So, I have had my Bonneville in to numerous repair places and they can't seem to figure this one out. So when driving and I start to slow down maybe about 5 or 10 MPH and then I put my foot to the accelerator lightly the engine seems to bog down. It's kind of weird. Even had it to my Trans Guy and he does not see anything wrong. It's kind of an odd problem but it's like my shimmy of my right front wheel at speeds above 50. No one seems to find a problem.
Anyone have these issues?
[/color]2001 Black Bonneville SSEi (BonneBill)
Original owner
Mods: 3.4 pulley, Intense Stage 1 Computer, cool air, ZZP Aluminum Valve Covers, Cross Drilled & Slotted Rotors front and rear, 180 degree drilled therm.
2007 Ford F350 (Harley Davidson Ed.) Turbo Diesel - Real Trucks Don't Have Spark Plugs!
Original owner
No More Car Payments for ME!!!!
PostPosted: Fri May 01, 2015 5:27 am
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
You might be able to isolate it by having someone else drive while you read a scan tool.
PostPosted: Fri May 01, 2015 5:48 am
Year and Trim: 2002 Bonneville SLE
Any codes?
PostPosted: Fri May 01, 2015 8:36 am
Sounds like you maybe need to get new plugs and wires. Would be worthwhile to clean the throttle body itself and the sensors, if it's never been done.
PostPosted: Fri May 01, 2015 11:29 am
I get no codes. As far as cleaning sensors, replacing plugs and wires. I have never cleaned any sensors but have had the plugs and wire replaced a couple of times. I was looking at doing the throttle body upgrade after polishing. But these I am willing to try.
Original owner
Original owner
PostPosted: Wed May 06, 2015 9:08 pm
Year and Trim: 2000
I was having similar issues. Was convinced my trans was going. Found bad spot on spark plug wire where the wire and plug head cover meet....replaced that one wire.....now it runs like a dream.....
PostPosted: Mon May 11, 2015 12:37 pm
Well my plug wires where just replaced because of another issue that it fixed, but my trans guy says that mine is perfect. I've changed my fluids every 15k and had my trans guy just keep a good eye on my trans. But I do want to look in to the sensors that where mentioned above. Can someone specify which sensors? I have never cleaned or replace any sensors.
Thanks
Original owner
Original owner
PostPosted: Mon May 11, 2015 4:12 pm
It wouldn't hurt to check the spark plug wires again. You never know. - BC
EDIT: after you do check them again, just for "fun", when it's dark, run the engine and open the hood and see if there's anything unusual going on. - BC
PostPosted: Wed May 13, 2015 12:13 am
I guess it wouldn't hurt
Original owner
Original owner
PostPosted: Wed May 13, 2015 11:33 am
1998 SE
2001 SSEI
2002 SSEI
A faulty throttle position sensor can be one source of trouble but they can't be cleaned.
Scotty Kilmer is a bit of a character, but makes decent how to videos about car issues and how to fix them. This one is about throttle position sensors https://www.youtube.com/watch?v=cPkk6md3Sy0
MAF sensors are a potential trouble source which can be cleaned with a special MAF sensor cleaner, designed to leave no residue behind that would interfere with sensor operation.
Here is a good video about it https://www.youtube.com/watch?v=xQGSkWEC_u4(You can skip the intro by jumping to 18 seconds).
With a different cleaner, you can also clean IAC valves and throttle plates and again, videos are on youtube.
These latter 2 items would more often affect idle.
PostPosted: Thu May 14, 2015 12:17 pm
Thanks for the input MKMike. I will look in to these and see if this is a problem. Right now this is a bit of a project car, but I am wanting to get it as close to the way I purchased it as I can. I'm buying all new tail and headlights and new paint job. I may be purchasing a replacement sun roof soon as well, but I really need to get these little mechanical issues done first.
Original owner
Original owner
PostPosted: Thu May 14, 2015 7:09 pm
1998 SE
2001 SSEI
2002 SSEI
Personally, I can't stand having anything not functioning the way its supposed to on a car--new or old.
If it's broken I just have to fix it.
PostPosted: Thu May 14, 2015 7:44 pm
What condition are your engine/transmission mounts in?
PostPosted: Sat May 16, 2015 6:16 pm
Had all of those replaced about a year ago. They where in bad shape. Really had never heard of the hockey puck fix. But to late now just had them done so I should be good for some time.
Original owner
Original owner
PostPosted: Sat May 16, 2015 6:19 pm
I agree with you. The problem is I have my Diesel pickup that was taking most of my cash for upgrades and some engine jobs, so the bonnebill got neglected. See I have one of the finicky Ford 6.0 diesels that has had issues. This was the last of the International engines for Ford, so a lot of work had to go in to it. Now I have some time and money to work on the SSEi and get it back to pristine working order. I am kind of excited to get it done. I really want to get it to as close to the way I got it when it was new!
Original owner
Original owner
There are no new unread posts for this topic. Can somebody figure this out?
terrancew3
Tue May 06, 2014 11:13 pm
Archon View the latest post
There are no new unread posts for this topic. Can't figure this out...
MKMike
Tue Feb 06, 2018 12:08 pm
96 SSEi View the latest post
There are no new unread posts for this topic. I cant figure it out
roworld
22
2962
Sat Feb 18, 2012 10:09 pm
There are no new unread posts for this topic. The mechanics can't figure it out
Franksdad
Fri Jun 28, 2013 9:02 am
There are no new unread posts for this topic. Figure this one....my car rides like a tank!
steelergrl74
Sat Mar 31, 2012 12:44 pm
Ken_W View the latest post
Users browsing this forum: Exabot [Bot] and 3 guests
