It is currently Mon Feb 17, 2020 9:16 pm
PostPosted: Mon Mar 23, 2015 9:47 pm
Year and Trim: 2004 3.6L V6 SLE
Hello everyone, first time poster. I'm looking at potentially buying an 04 bonneville V6 SLE. The car seems to be in great shape, apart from one issue and I'm just curious if anyone else here has had the same problem. When accelerating hard ish in low gears, the transmission seems to slip and let go for a second and the engine revs much higher. It's almost like it's shifting into neutral for a second before it shifts up because the rpms go way up for about a second. I've read that the pressure control solenoid can be an issue with this car, could that be what is causing this? Appreciate any insight anyone can provide. Thanks!
PostPosted: Mon Mar 23, 2015 10:06 pm
Welcome.
Does this happen when the transmission is warm? Or fresh off the lot?
"Penelope" - 2003 SLE - 203k Miles
"Sydney" - 2000 Honda S2000 - 71k miles
PostPosted: Mon Mar 23, 2015 10:09 pm
Fresh off the lot, we had not been driving more than 2 minutes. The car had been running for 10-15 minutes idling beforehand though.
PostPosted: Mon Mar 23, 2015 10:15 pm
So I assume you're driving along at like 30 mph and you nail it and it does this? Or is the 1-2 shift at WOT?
Miles on the car?
PostPosted: Mon Mar 23, 2015 10:20 pm
well I'm from the great white north, so it's got 188,291 km. So around 118K miles? I believe it was when shifting from 1st to 2nd. It was probably a little slower than 30mph, more like 15-20 mph. Not fast at all.
PostPosted: Tue Mar 24, 2015 8:10 am
Could be a trans mount, or it needs a shift kit.
There are no new unread posts for this topic. Bad PCS? Transmission Slipping
pinstriper38
Thu Oct 15, 2015 8:26 pm
pinstriper38 View the latest post
There are no new unread posts for this topic. slipping transmission
wiro01sle
Wed Jan 05, 2011 11:47 am
There are no new unread posts for this topic. Re-Built transmission slipping again in less than a year
Namrepus28
29
1129
Mon Apr 15, 2019 2:07 pm
Namrepus28 View the latest post
There are no new unread posts for this topic. Strange vibration and slipping Transmission
2000Silverbullet
15
2006
Tue Jun 09, 2015 1:26 pm
Archon View the latest post
There are no new unread posts for this topic. slipping and sliding in OR
spoiledred94
Tue Feb 11, 2014 10:57 am
