It is currently Sat Jun 06, 2020 2:06 pm
Post new topic Reply to topic  [ 15 posts ]
PostPosted: Tue Feb 24, 2015 2:49 pm
Ok my 02 Bonnie sle abs light came on followed by the traction control light shutting off, then out of the blue my no traction light came on and my car acted like as if I was stopping on ice, rainy weather. (Of course it's sunny and dry at the moment) autozone scanner said zero reading on front passenger hub so in research my sensor is probably bad? Questions are....
1. Can I continue to drive???
2. Will just unplugging the sensor temporarily work - could I still drive.
3. If and if possible, can I unplug the abs fuse and drive??
I just want to make sure I will be ok to drive till I fix and if I can do anything to stop the abs from freaking out till then. I've seen mixed reviews on this butchered enter to get info than from my fellow Bonnie lovers. Thank u for your time
PostPosted: Tue Feb 24, 2015 3:30 pm
Year and Trim: 2004 GTO
If you pull the fuse that should stop the abs pump from activating. You'll still have brakes just no anti lock or traction control. Also check the wiring at the sensor, could just be a bad wire.
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Tue Feb 24, 2015 3:35 pm
Year and Trim: 1993 SSE Medium Garnet Red Metallic, Gray
ABS "Ice Mode" is dangerous, if not just plain suicidal for everyday driving. The only use for it is to give a driver that last opportunity to deflect a path of travel when the road surface to tire coefficient of friction is extremely low, and perhaps minimizing the severity of an imminent crash.
My '93 SSE did the same thing. Only quick thinking, and a good parking brake kept me from a crash. I pulled the 30 amp ABS control fuse.
That leaves the ABS and TC lights on. The car will not have TC or ABS.
The brakes will otherwise function normally. But you will be able to lock them up. It is then like driving a pre-ABS car.
Since my car falls into the "OBD1.5" category, it is hard to find an answer to what specific component is the root of my problem.
For you, at least you know where the issue is originating. But I am not sure what effect disconnecting the sensor would have.
By pulling the fuse, you disable the ABS pump's ability to reduce or modulate hydraulic pressure to the wheels.
Not that many years ago, GM had to issue a recall for the Yukon/Tahoe/Suburban/Silverado 4WD trucks. Corrosion would cause problems with the front wheel sensor trigger wheels, interrupting the signal. A bunch of "Can't Stop!" ABS related rear-end crashes happened; customers and the NTSB jumped on GM about the problem. ABS is a great thing to have, when it works reliably. But when it fails in activated mode, braking distances are greatly increased, and braking power/effectiveness is drastically reduced. Nothing to take a chance on.
Alan Sheidler
Proud Third Caretaker of the Family Heirloom '93 SSE
Medium Garnet Red Metallic, Gray Leather Interior
Silver Cross-Lace Wheels (I love this car)
PostPosted: Tue Feb 24, 2015 3:41 pm
Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
Living on the west coast I often wonder if abs is even necessary. There are times where I hit a series of bumps, say a slightly angled bridge that is about an inch higher than the road surface and it activates the abs dropping my braking power. It used to happen in the same spot every day on my way home from work, and the bridge was about 50' from a stop sign on a 50+ mph road. Drove me nuts in my Sierra.
PostPosted: Tue Feb 24, 2015 3:55 pm
There is a curving road with a hill that has ripples in the pavement on the "going down" side. A traffic light intersection is at the bottom. Traffic backs up sometimes. I can't be the only driver to have ever gotten ABS activation over those bumps, making me wonder whether it would cause me to hit a vehicle in front of me. I don't use that road much in that direction, particularly in wet weather. Lockup is preferable to a crash.....
Alan Sheidler
PostPosted: Tue Feb 24, 2015 3:57 pm
Yeah, I'd much rather the back end wiggle a bit than have the brakes not work at all.
PostPosted: Tue Feb 24, 2015 6:47 pm
Lol both wonderful responses yet two different again. So it's ok to pull the abs fuse and drive, it just won't have abs but I will still have brakes I can still drive and stop etc....am I correct? And in doing this I wont damage anything?
PostPosted: Tue Feb 24, 2015 7:16 pm
Year and Trim: 2004 GXP
Everyone is essentially saying the same thing. Yes, it's ok to pull the fuse and drive, you just won't have ABS or Traction Control so drive accordingly.
2004 Bonneville GXP Crimson Tintcoat- Casual fuel gauge | Brake Performance drilled/slotted rotors front and rear| Retrofit Morimoto mini H1 | clear corners | disabled DRL | 3000K HID fogs | 5% tint | K&N | Yakima rack with fairing, bike rails and kayak rack | Intermittent radio display
1995 Bonneville SSE Deep Amethyst Pearl- SSEI tails | 5% tint | 3 12jlw3v2 in custom enclosure -Gone
1991 Bonneville LE Blue- Alloy spokes -Deceased(deer)
PostPosted: Tue Feb 24, 2015 8:06 pm
Thank you! Sorry for being slow I appreciate your feedback!
PostPosted: Tue Feb 24, 2015 8:18 pm
Excuse me sorry, but I'm see it says a 10 amp abs fuse and I read about a 30amp one.....know where it is? If two which do I pull? Thank you again!!
PostPosted: Tue Feb 24, 2015 8:24 pm
Definitely consult your owner's manual for the location.
Mine was in the main fuse panel in the engine compartment, up against the top of the firewall, behind a plastic cover. That cover is a pain to get off, and harder to reinstall. Yes it was a 30 amp fuse. It is big.
Yours is a newer car, and the setup may be different. Remember, my car is a '93.
But realize that you want to pull the fuse which deactivates the ABS/TC pump. 10 amps seems way small for that job, more likely to be part of a triggering or warning system than power to the pump itself.
There are commonly now two fuse panels for cars, and have been for some time. The one you want to get to is the main one, where there are big circuit breakers and relays, not just the little plug-in fuses which are used for lights, etc. The "Heavy Duty" main panel is in the engine compartment. The smaller one is usually in the passenger compartment close to the dash... Wish I knew your generation of car better, hope someone else will chime in and point you to the exact spot.
Alan Sheidler
PostPosted: Wed Feb 25, 2015 2:39 am
You've been amazing thank u
PostPosted: Wed Feb 25, 2015 5:13 pm
I believe the 2000+ models have 3 fuse blocks. One next to the battery, under the back seat, one under the hood (my money on where the ABS fuse is) and one by the drivers feet.
Also, your tire pressure monitoring uses wheel speed sensors too, so that is one more thing to be aware of and keep tabs on.
PostPosted: Wed Feb 25, 2015 5:20 pm
2000+ have two fuse blocks. One under the back seat, and one under the hood. ABS is under the hood.
PostPosted: Wed Feb 25, 2015 5:57 pm
Awesome thank u
There are no new unread posts for this topic. Should Check Engine light come on when unplug MAF sensor?
Ken_W
Sat Oct 29, 2011 6:25 pm
Ken_W View the latest post
There are no new unread posts for this topic. unplug injector electrical connection due to miss.
96 SSEi
Mon Aug 20, 2018 10:55 am
There are no new unread posts for this topic. ABS code 'C1245-Acceleration Sensor Output'-sensor location?
Teearohwhy
Fri Dec 14, 2012 12:37 am
Archon View the latest post
There are no new unread posts for this topic. Car Stalled In McDonalds Drive Thru
ColJy
Sun Nov 24, 2013 10:45 pm
DaMaroon View the latest post
There are no new unread posts for this topic. Reprogramming for different final drive
bogard985
Wed Jun 28, 2017 10:15 am
bogard985 View the latest post
Users browsing this forum: No registered users and 15 guests
