It is currently Fri Jul 10, 2020 7:44 am
PostPosted: Fri Nov 07, 2014 7:48 pm
Ok everyone!
I have a variation of the power window, door lock, mirror issue that I have not seen in the forum.
It is on 2005 SLE.
Everything works normally if the driver door is open most of the way.
If door is closed or mostly closed, then passenger windows do not work (from the driver door or individually), power locks will not activate from driver door or passenger door, same for passenger mirror. Driver door components will work regardless of the driver door position.
With driver door closed, information center does not report an open passenger door. As soon as driver door is open, passenger door is reported open as normal.
Pulled driver seat to check for the corrosion issue, (seat is a bear to remove and install without dinging up paint and door panel), 2005 has wiring in plastic channel off the floorpan and area was dry and no evidence of moisture. Did not find any corrosion.
Is this a door module issue or something else? Ideas? Is there one wire that would disable everything if broken.
Thanks!
PostPosted: Mon Nov 10, 2014 8:25 am
Year and Trim: 97 SE w/L67
Gotta be a broken wire between the door and body.
PostPosted: Mon Nov 10, 2014 1:27 pm
Year and Trim: 2004 GTO
Check the battery and all of the grounds on the car. Another one of our members had a similar issue and the battery and also the stud on the fuse box was the issue.
general-chat/topic44535.html
-Ryan
2004 GTO....LS1, 6MT
yourgrandma wrote:
Hi.
PostPosted: Mon Nov 10, 2014 11:51 pm
Year and Trim: 2004 SLE Premier Edition
2005 GXP
I would start here.
Very common and easy to get to.
Pull the boot back between the drivers door and body and look for broken wires.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
There are no new unread posts for this topic. Power door lock and Window problem
Vic HIx
Tue Jun 07, 2016 4:15 pm
Vic HIx View the latest post
There are no new unread posts for this topic. 2000 SLE Power door lock/window issues
bing98
Mon Mar 24, 2014 7:58 pm
There are no new unread posts for this topic. Drivers door window, mirror and lock, but no where else{FIX}
redfury
Fri Jul 08, 2016 8:42 am
redfury View the latest post
There are no new unread posts for this topic. 2002 ssei door lock and window problem.
flopo
Sun Aug 05, 2012 6:32 pm
flopo View the latest post
There are no new unread posts for this topic. Power Door Locks: Lock, but don't Unlock
chuckk_
Sat May 25, 2013 9:08 pm
jongwong View the latest post
