It is currently Mon Feb 17, 2020 8:06 pm
PostPosted: Tue May 13, 2014 4:07 pm
Year and Trim: 2000 ssei
I tried to take a video of it, but it is too faint for my phone to pick it up. It doesn't sound like a distinct knock sound, it sounds more like a rattle than a knock and Iv'e only been able to hear it so far with the car in park or N. Doesn't matter if the engine is cold or warmed up and it seems to be coming from the bottom of the engine and it most noticeable under the car. It goes away under 1k rpm's, and when you get up near 2k rpm's.
PostPosted: Tue May 13, 2014 4:19 pm
Could be the harmonic balancer. The rubber in them can deteriorate and let it rattle. Grab one of the serpentine belts (with the car off) and see if you can move it along it's path by hand. Also get a flashlight and look to see if it looks at all cracked on the outer face near the rim. The face is often painted so it's hard to tell, but there's an outer hub, a rubber middle section, and a metal inner hub. There are teeth buried inside that keep the outer hub spinning if the rubber fails. Those teeth can make quite a racket when the rubber cracks all the way around.
PostPosted: Tue May 13, 2014 5:39 pm
If your phone can't pick the noise up it isn't the harmonic balancer, those sound like the bottom end is going to come apart, a phone would surely pick that rattle up.
Maybe the catalytic converter or downpipe rattling? Go underneath and give the cat a good swat and see if it rattles at all.
PostPosted: Tue May 13, 2014 8:35 pm
https://www.youtube.com/watch?v=12GqQ-7 ... e=youtu.be I was able to capture it from underneath the car
PostPosted: Tue May 13, 2014 8:42 pm
That sounds like bottom end to me.
PostPosted: Tue May 13, 2014 9:19 pm
Agreed, doesn't sound good.
PostPosted: Wed May 14, 2014 1:11 am
Give it some quick revs not a constant RPM... you should be able to hear any knocking better that way.
-Andrew-
PostPosted: Wed May 14, 2014 10:29 am
Sounds like a rod bearing. #-o
2000 SSEi - SilverBullet - 78,000 kms, 4" "straight shot" custom headlight ram air inlet, TOGs, 1.9's, Lsd, 2.9-3.4"MPS 10-15 psi, Ported GenV, EGR eliminated, OR pushrods, oil volume kit, trani cooler & shift kit, Titanium retainers, 90 lb springs, 160 Stat, 42# injectors, Fuel pump voltage increase, Wideband O2, 3" to dual 2 1/2" Magnaflows, Snow Meth/water injection, after SC temp gauge, 255/50WR17, timing commander set 15-18*@WOT, 2 speed Fan over-ride, disabled DRL, Solid motor mount, Meziere Electric water pump, adjustable fuel pressure regulator, Drilled & slotted rotors/ceramics, GXP sway bars and STB, Upgraded and rebuilt transmission, Pioneer Bluetooth stereo with sub and 800 W amps, PB 13.5 quarter, (April 2014 car of the month)
PostPosted: Wed May 14, 2014 4:45 pm
I don't hear it any better with quick revs. It's weird that it's only audible between 1-2k rpm's...only underneath the car.
PostPosted: Wed May 14, 2014 5:13 pm
Loose TC bolts? Simple to inspect.
PostPosted: Wed May 14, 2014 5:38 pm
I will check those and get back to you.
PostPosted: Wed May 14, 2014 6:47 pm
It seems the loudest around the oil pan area. I stuck my head under there while someone held the rpm's at 1500 or so. I mean im not 100% sure thats exactly where its coming from. It doesn't 100% sound like a knock, it only does it at certain rpm range which doesn't make sense to me. But the only semi logical explanation is rod bearing knock.
There are no new unread posts for this topic. 2000 SSEi Engine Rod Knock, Engine Repair Options?
20SSEi00
Fri Apr 20, 2018 7:04 pm
20SSEi00 View the latest post
There are no new unread posts for this topic. Rattle in rear of 2000 .
kennyz
Sun Nov 08, 2015 9:14 pm
There are no new unread posts for this topic. 2000 Bonneville SLE front suspension rattle
Bonneville'sRock
Wed Apr 02, 2014 1:11 pm
Archon View the latest post
There are no new unread posts for this topic. Fuel pump swap?: 2000 LeSabre(L36) to 2000 SSEi(L67)
Junior28
Tue Jun 24, 2014 2:45 pm
There are no new unread posts for this topic. Engine knock/rattle noise
quicksilver
Fri Mar 04, 2016 10:25 am
MKMike View the latest post
Users browsing this forum: No registered users and 16 guests
