It is currently Wed Dec 02, 2020 9:07 pm
PostPosted: Mon Apr 21, 2014 3:59 pm
So I'm wondering if anyone has done this?
I read in the manual that you have to remove the rear exhaust and one of the steering tie-rod ends. True?
My TOGs clear the bar for more than the stock exhaust.
Hopefully it won't require a sub frame drop.....
Swapping the hollow stock one for a solid GXP unit. 50% stiffer
I don't imagine the rear bar will be difficult at all.
Any advice at all is appreciated. I have elicited the help of one who will do the night shift....
PostPosted: Mon Apr 21, 2014 7:29 pm
Year and Trim: 2001 SSEi
No advice, I'm just hoping for some input on the same issue, as I just picked up a complete GXP suspension for my SSEi and will be putting it in this summer. I'm also curious to see how much those typically go for. It came out of a 2004 GXP with 70,000 miles.
PostPosted: Mon Apr 21, 2014 7:51 pm
1991 SE
We had to drop the sub frame when we did mine. Even then it did not just slip in. But we did not mess with the exhaust.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
PostPosted: Mon Apr 21, 2014 8:07 pm
Year and Trim: 00 Regal
It should pop out one of the sides with the wheel off. If you need to lower the rear of the subframe, it's only an inch or two. IIRC though you can wiggle and slide it right out.
97 Ei
97 GS
98 GS
PostPosted: Mon Apr 21, 2014 9:23 pm
The book says you have to drop the rear exhaust and break one of the tie-rod ends then it should slide out.....hmmm
My exhaust is not stock so maybe I can get away without breaking anything as Bill says.
I'm doing this mod a few hundred miles from home in another country over a weekend so I would prefer not to have to disturb the subframe. #-o
There are no new unread posts for this topic. Front Sway bar
irish91983
Sun Feb 17, 2013 5:21 pm
irish91983 View the latest post
There are no new unread posts for this topic. 2000 SSEi Sway Bar Replacement
2000Silverbullet
Mon May 12, 2014 3:09 pm
There are no new unread posts for this topic. front sway bar links
MrT
Fri Apr 04, 2014 11:50 pm
MrT View the latest post
There are no new unread posts for this topic. Newbie sway bar bushing replacement questions
Ken_W
Sat Sep 18, 2010 6:50 pm
carl View the latest post
This topic is locked, you cannot edit posts or make further replies. Front suspension replacement
bopguy
Tue Oct 30, 2012 8:44 pm
repinS View the latest post
