It is currently Thu Jun 04, 2020 1:40 pm
PostPosted: Wed Apr 09, 2014 5:42 pm
Year and Trim: 2002 Bonneville SSEI Midnight Blue 110k
I've got a rattle that seems to be coming out of my trans. The torque converters bolts have been tightened to see if the rattle was that, and it's still rattling. The next guess is that it's the flywheels bolts that are loose. Is it possible to tighten these without remove the transmission? My dad said I should be able to take off the flywheel access panel, and tighten one bolt at a time, by turning the engine slowly.
Thanks for the help!
PostPosted: Wed Apr 09, 2014 5:48 pm
Year and Trim: 1988 LE
Not gonna happen without at least moving the trans a couple inches away from the engine. The TC is too close to the bolts to get a wrench in there. Maybeee if you unbolt the 3 converter bolts i believe it will have a little play, i doubt it's enough but worth a try.
What makes you think its the tranny though?
-Austin-
yourgrandma wrote:
And thats how I got my mom pregnant.
PostPosted: Wed Apr 09, 2014 8:04 pm
Year and Trim: 00 Regal
It would be super painful to do with the trans in. I think the converter will slide back..maybe just far enough. Problem then is ..there really isn't much room between the bolts.
97 Ei
97 GS
98 GS
There are no new unread posts for this topic. 2000 lesabre ,,tranny seems to slip a second when taking off
cvcman
Sat Feb 25, 2017 3:32 am
rynmcdonald View the latest post
There are no new unread posts for this topic. How do I tighten ICM and ECU connections?
MKMike
Fri Oct 25, 2019 12:49 am
95naSTA View the latest post
There are no new unread posts for this topic. 2001 SSEi center cap tighten
jddem
Mon Feb 09, 2015 5:16 pm
jddem View the latest post
There are no new unread posts for this topic. Battery Replacement - Positive Terminal Won't Tighten
iceman99uc
Tue May 06, 2014 7:49 pm
iceman99uc View the latest post
There are no new unread posts for this topic. Start Doesn't Catch FlyWheel
jaycay99
Sun Aug 28, 2016 7:44 pm
Oldman View the latest post
Users browsing this forum: Google [Bot] and 14 guests
