It is currently Sat Feb 16, 2019 4:08 pm
 Post subject: Shifting issues
PostPosted: Thu Feb 06, 2014 9:55 pm
Year and Trim: 2009 G8 GXP
Since I work all day, I have to have school at night. And lately with the frigid temperatures outside, my car is ice cold in the parking lot at 10:00 pm when I leave. And since I don't have remote start and I don't want to sit and wait for my car to warm up to operating temp, I just start it and go after a few minutes.
Well, the fastest way home is to hop on the nearest highway, which is less than 2 miles away. So my engine temp barely gets to 150 degrees before I get on the highway. After I get on, it seems like my gears shift fine between 1st, 2nd, and 3rd, but it wont shift into 4th (O/D) until my engine temp gets to about proper operating temp. So for a couple miles my RPM's sit at about 2,500-3,000 at 70 mph and my gas mileage just drops then. Is there a solenoid or sensor I can swap out to see if that is causing the shifting to be bad, or is this just a normal thing at cold temps?
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
 Post subject: Re: Shifting issues
PostPosted: Thu Feb 06, 2014 10:22 pm
Your trans won't go into overdrive(4th) until it reaches 80*F, if I remember correctly.
PostPosted: Thu Feb 06, 2014 10:43 pm
2004 Bonneville GXP
All the shift solenoids are internal on the transmission. You have to remove the valve body to get to them. It could be a number of things. Go on the triple edge performance website and you may find the cause.
bobgto65
PostPosted: Fri Feb 07, 2014 12:13 am
Year and Trim: 2002 bonneville ssei
124k
Stock for now
i work midnights so i know how this is.. i generally let mine warm up and it still takes a minute to srop into overdrive. like it was said above its something with tranny temps.
PostPosted: Fri Feb 07, 2014 12:18 am
Normal at cold temps. Usually takes 2-3 miles to kick into overdrive from a cold start with minimal warmup (20-30 seconds).
-Andrew-
PostPosted: Fri Feb 07, 2014 10:15 am
Year and Trim: 2003 SSEi.
LOTS of Mods
the TCC wont lock until the Coolant temp reaches 100*F
PostPosted: Fri Feb 07, 2014 11:58 am
Year and Trim: 2000 SSEi: Black w/ 145,XXX miles
Even with the freezing cold temps (5°), my car would have warmed up after two minutes of idle to about 150°. Then when I hit the road it reaches operating temp and *shoot* into 4th no problem. If you do let it sit for the two full minutes you should be alright.
Also, did you drill you t-stat? That would make it take longer to warm up then..
1995 Jeep Cherokee Country- 200,XXX miles and running strong. 4.0L paired with a 5 speed manual. 4.5" long arm lift with 32" tires and regeared to make up for power. Best of all, shes a fire engine red!
2000 Bonneville SSEi- 145,XXX miles, bonestock for the time (don't hold your breath, it might be a long while)
Typos courtesy of LG Optimus G- yes, I do most of my trolling with my phone. Don't judge me.
PostPosted: Fri Feb 07, 2014 6:32 pm
No, I believe I have the 180 degree t-stat. It only seems to have issues when its hovering around the 0 degree or less range.
2005 Grand Prix
There are no new unread posts for this topic. Shifting issues
william003
Fri Aug 24, 2018 2:37 pm
william003 View the latest post
There are no new unread posts for this topic. HELP! Oil Pressure issues/ Knocking/ Boost issues
Renegade
Thu Jun 05, 2014 7:31 am
Renegade View the latest post
There are no new unread posts for this topic. Hard shifting
danny4748
Mon Jul 25, 2011 6:44 pm
danny4748 View the latest post
There are no new unread posts for this topic. Transmission Shifting
Tight
Fri Apr 08, 2011 9:29 am
Archon View the latest post
There are no new unread posts for this topic. Shifting problem.
darwinm
Fri Nov 14, 2008 9:42 pm
Whitecrystal1 View the latest post
Users browsing this forum: ibisjoe, luke_dubs and 10 guests
