It is currently Mon Jan 21, 2019 1:31 pm
 Post subject: 02 sensors
PostPosted: Fri Aug 08, 2008 2:51 pm
Year and Trim: 2000 SSEi Dark Blue Matallic
3.4 pulley
How hard is it to remove the 02 sensors. Being in the exhaust pipe I would think rust, heat and corrosion would make very hard.
 Post subject: Re: 02 sensors
PostPosted: Fri Aug 08, 2008 2:54 pm
i've never had a problem. The 02 sensor socket makes it a lot easier (has a slot for the wire)
PostPosted: Fri Aug 08, 2008 2:57 pm
3.4 pulley
Thanks for the come back . I guess I will do it myself. By the way are sockets readly avilable?
PostPosted: Fri Aug 08, 2008 3:20 pm
Year and Trim: 1997 SE
I've found that it's somewhat easier if you have things warmed up first. Not 3 hour trip hotter than the hubs of heII hot!
Plus, I will often use some PB blaster at least a 1/2 hour before attempting removal, if I have time.
O2 sensor sockets can be readily obtained at local parts stores, including at Harbor Freight of all places.
PostPosted: Fri Aug 08, 2008 3:25 pm
yeah, i can't remember if i got mine at checker, or maybe autozone. one of your local parts shops should have it.
PostPosted: Fri Aug 08, 2008 5:15 pm
Year and Trim: ____
And just in case you don't already know...you only need to replace one, the upstream sensor, every 100k. The second is there to indicate the functionality of the catalyst.
John
PostPosted: Fri Aug 08, 2008 5:34 pm
3.4 pulley
I have heard the one by the catalytic conferter is the one that affects gas milage if it is bad.
When you talk about the one up stream is that the one up by the engine?
PostPosted: Fri Aug 08, 2008 5:54 pm
Year and Trim: ____
Yes, the upstream sensor is the one that you want to change. That is the one located just under the firewall, directly back from the rear bank's manifold, before the catalytic converter. The one after it does not need to be changed unless it is malfunctioning. If you get a code for Bank 1, Sensor 2, the downstream sensor, this is indicating that the catalytic converter is no longer functioning as it was designed to, and must be replaced. If not replaced, will eventually clog.
John
PostPosted: Fri Aug 08, 2008 10:47 pm
yup. the first one makes the adjustments, the second one after the cat is just the last sensor in the system, making sure everything else was working fine.
There are no new unread posts for this topic. O2 sensors
In_da_boondocks
Mon Mar 15, 2010 5:11 pm
In_da_boondocks View the latest post
There are no new unread posts for this topic. How many O2 sensors...
Paragongx
11
6149
Sat Aug 14, 2010 6:00 pm
There are no new unread posts for this topic. How many O2 sensors ?
ytd1861
Tue Apr 16, 2013 3:52 pm
ytd1861 View the latest post
There are no new unread posts for this topic. o2 sensors
dragonsfire117
Thu Mar 26, 2015 10:52 pm
Archon View the latest post
There are no new unread posts for this topic. Help with O2 sensors
irad
Wed Jun 13, 2018 8:41 pm
irad View the latest post
Users browsing this forum: Google [Bot] and 10 guests
