It is currently Tue Sep 22, 2020 1:27 pm
PostPosted: Fri Jan 17, 2014 5:44 pm
Year and Trim: 2001 SSEi
Around Christmas time, I noticed that my car was pulling hard to the right. After some investigation, I am more confused now than before I started looking.
Wheel bearings have no play and seem fine.
Tire pressure is even all the way around.
Pulling does not increase or decrease when I apply brakes.
Pulling does not increase or decrease when I speed up, slow down or put in neutral while going down the road.
I jacked up each front wheel and put the car in gear and noticed that I have separations in both front tires, but I don't know if this could cause the pulling to the right, or if is a result of the pulling to the right due to an alignment problem.
I'm broke after getting Christmas paid for and am currently working two jobs to make ends meet, so I have little time or money to take it to an alignment shop.
Just looking for any advice anyone might have about what would cause this to happen all of a sudden. No, nobody has wrecked my car recently, and no, I haven't hit any large potholes, bumps or curbs.
Thanks for your help!
PostPosted: Fri Jan 17, 2014 6:23 pm
Tire issues can cause pulling. In my one experience with it, the tire didn't live long after it started the pull.
PostPosted: Fri Jan 17, 2014 6:33 pm
Try a DIY alignment until you can have the pros do it?
https://www.youtube.com/watch?v=7aw9ZIO0JFM
-Andrew-
PostPosted: Sat Jan 18, 2014 12:06 am
Year and Trim: '93 SSEi
'05 STS-4
'97 LeSabre
Based on the description, I'd say bad ball joint or tie rod end. jack the tire up, force it back and forth between 3 and 9 o'clock [tie rod end] or at the 4:30 (passenger side) / 7:30 (drivers side) [ball joint] with a helper to watch for wiggle in the [tie rod end] or [ball joint]. You should also feel any looseness as a clunk while your force it back and forth.
If everything in the front end checks out, swap tires to see if the pull changes at all.
upkeep on K2500 and 97 LeSabre
PostPosted: Sat Jan 18, 2014 2:10 pm
Thanks Haro!
I always forget about Youtube!
There's some real garbage out there, but a few good ideas on adjusting toe-in/toe-out.
Thanks,
There are no new unread posts for this topic. Idling issues and hard shift
Alpine_jake
Mon May 27, 2013 1:14 am
Monkeybiz View the latest post
There are no new unread posts for this topic. Tranny issues....missing 2nd on hard accel
01bonneSC
Thu Jun 26, 2008 10:30 pm
SSEimatt93 View the latest post
There are no new unread posts for this topic. Hard shifts from stops, intermittent. Not front motor mount.
crunde85
Fri Sep 23, 2011 11:16 pm
There are no new unread posts for this topic. Attachment(s) one unhappy Bonne owner - front end issues.....again
ptrfair
Wed Feb 04, 2009 12:26 am
Archon View the latest post
There are no new unread posts for this topic. car pulls to the left,
Gumball
Tue May 15, 2012 11:27 pm
cron
