It is currently Tue Apr 16, 2024 3:15 pm
 Post subject: maf on 02 ssei
PostPosted: Wed Dec 11, 2013 10:06 pm
Year and Trim: 2002 bonneville ssei
124k
Stock for now
my 2002 check engine light came on on a road trip to ohio.. the whole trip i avg about 27mpg.. i got there and scanned the code to find out it as the MAF.. the same day i noticed under hard throttle the car will buck alittle bit..i figured these problems are related .. however im still not familar with a supercharged car as of yet . the car has not bucked like that since and has been a week now. and runs great. no drop in mileage other than due to cold weather, do you guys think maybe it just needs cleaned or is a MAF a common problem with these cars?
 Post subject: Re: maf on 02 ssei
PostPosted: Wed Dec 11, 2013 11:33 pm
Definitely try cleaning it with some CRC MAF cleaner spray. You'll need a T-20 Torx Security Bit to remove the maf. If cleaning doesn't resolve the code, replace it with one from a junk yard car, or get one from Andrew, Harofreak00. The reman maf's that they sell at the parts stores tend to fail quickly, OEM's are much better, or if you want to buy new, buy a Delco.
Joseph
1999 Infiniti G20T - Sold
PostPosted: Wed Dec 11, 2013 11:43 pm
124k
Stock for now
alrite thanks man. ill def clean it when i get the fenderwell intake
PostPosted: Wed Dec 11, 2013 11:45 pm
Sure thing! It's super easy, just be careful not to touch any of the filament wires inside it and you should be good.
Joseph
PostPosted: Sat Dec 14, 2013 10:55 am
Year and Trim: 2000 SSEi Stock.
Vacuum leak can also cause that code to throw. You might want to check that before spending money on parts. Fairly easy to spray some carb cleaner on the vac lines with engine running and watch for any change in rpm.
My experience has been that if the car still runs, the maf isn't the problem. When my maf did actually fail, the car would not run. That's just MY experience.
PostPosted: Thu Dec 19, 2013 11:29 pm
124k
Stock for now
update.. i unhooked the sensor... does nothing to the idle.. i went ahead and cleaned it even tho it didnt look dirty.. put it back in let it idle and drove it.. no change what so ever..
PostPosted: Fri Dec 20, 2013 5:47 pm
124k
Stock for now
can anyone help? i assume its a bad sensor
PostPosted: Fri Dec 20, 2013 6:06 pm
It could be a bad sensor, cleaning doesn't always help them. When mine failed, it didn't throw a check engine light, the car would just die like you turned the key. I unplugged it, and no change. Replaced the MAF and all was good.
Do you know what the exact code was? Like the number? It should be a P0xxx code.
Joseph
PostPosted: Fri Dec 20, 2013 6:13 pm
124k
Stock for now
no i knew the guy working there and he said MAF sensor. he cleared it and came back on... went off again then came on and stayed since
There are no new unread posts for this topic. Can I use a 2003 or 2000 SSEI trans in2001 SSEI
MKMike
Mon Oct 28, 2019 8:56 am
peter View the latest post
There are no new unread posts for this topic. Attachment(s) SE cluster in SSEi... now GXP in SSEi
7191
Sun Jul 10, 2011 9:00 pm
There are no new unread posts for this topic. 00 SSEI EGR
tracker9118
Thu Jan 15, 2015 9:21 pm
robauto View the latest post
There are no new unread posts for this topic. just got my first ssei
mfcordova2008
Sun Jan 30, 2011 11:14 pm
There are no new unread posts for this topic. Ssei
Jnegrea93
Sat Oct 18, 2014 6:45 am
mrrcom View the latest post
