It is currently Thu Feb 21, 2019 1:48 pm
PostPosted: Thu Oct 31, 2013 6:40 pm
Year and Trim: 2009 G8 GXP
How come at random times, when I turn at slow speeds (approximately 5 to 10 mph or less) it sounds like my power-steering binds up. It only happens on slow right turns, and never on the left. And it only lasts for a short second, if not faster. All it does is makes a bzzzz sound, and I can feel my steering wheel vibrate slightly. But like I said, its only at random times. It never has done it consistently.
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
PostPosted: Thu Oct 31, 2013 7:34 pm
Year and Trim: 1995 se bonnie
power steering rack starting to go bad?
1995 se
128,101
custom FWI
rt-95 rims look kinda like crosslaces
6000k hids
f- body muffler dual output
96-99 headlight conversion, clear markers
PostPosted: Thu Oct 31, 2013 7:53 pm
Possibly, this:
Quote:
File In Section: 02 - Steering Bulletin
No.: 99-02-32-007A
Date: February, 2001
TECHNICAL
Subject:
Steering Vibration/Shudder/Moan During Parking Maneuvers on Dry Pavement (Install Power Steering Pressure (Inlet) and/or Return (Outlet) Hose Assembly)
Models:
1995-99 Buick Riviera
1997-2001 Buick Park Avenue, Ultra
2000-2001 Buick LeSabre
2000-2001 Pontiac Bonneville
This bulletin is being revised to add the 2001 model year and to update the parts information. Please discard Corporate Bulletin Number 99-02-32-007 (Section 2 - Steering)
Condition
Some customers may comment on a steering vibration, shudder or moan noise when steering during parking maneuvers on dry pavement.
Correction
Install a new power steering pressure (inlet) hose assembly on the following vehicles:
^ 1995-98 Buick Riviera
^ 1997-98 Buick Park Avenue and Ultra
Install a new power steering pressure (inlet) and return (outlet) hose assembly on the following vehicles:
^ 1999 Buick Riviera
^ 1999-2001 Buick Park Avenue and Ultra
^ 2000-2001 Buick LeSabre
^ 2000-2001 Pontiac Bonneville Diagnosis
Important : In diagnosing the above listed vehicles, do not overlook other obvious repairs prior to replacing the hose(s).
1. Verity that the power steering pump reservoir is full.
^ If fluid level is low, till and check for leaks.
^ If power steering system has air in the system, perform the "Bleeding Air from Power Steering System" procedure as described in the Power Steering System sub-section of the Service Manual.
Important : When performing the "Bleeding Air from Power Steering System" procedure, it is important that the front of the vehicle is supported by the lower control arms. If the vehicle is not supported by the lower control arms, the procedure may cause the strut bushing to dislocate and cause new concern.
2. Verify that the accessory drive belt is in good condition and that the pulleys are not bent or damaged.
3. Verify proper belt tension and operation of the belt tensioner.
4. Check for power steering hose ground out conditions.
5. Check for good engine idle and correct engine RPM.
6. Check to see that the rear transaxle mount does not have a plastic assembly aid installed which is used for assembly purposes. If the assembly aid is installed, remove the assembly aid and install the rear transaxle mount.
7. With the vehicle on dry pavement, maneuver the vehicle in parking positions. If the steering vibrates/shudders or moans in this test, replace the power steering pressure hose and/or the harmonic balancer.
Important : A defective harmonic balancer on the 1995 Buick Riviera can influence steering vibrations after power steering hose installation.
PostPosted: Thu Oct 31, 2013 9:31 pm
I will check to see if its full tomorrow. What would inlet and outlet hoses have to do with the vibration though?
2005 Grand Prix
PostPosted: Fri Nov 01, 2013 9:05 am
Year and Trim: 2003 SSEi
Is the lounge the right place for this?
gweg_b wrote:
Resident Tightwad
Screw you, Photobucket.
PostPosted: Fri Nov 01, 2013 9:19 am
Year and Trim: '02 SSEi
Sounds ilke low fluid.
PostPosted: Fri Nov 01, 2013 7:12 pm
Eh, it might not be. But I was in a hurry to get something posted. I was busy all day yesterday, and had no time to sit there and figure out stuff.
2005 Grand Prix
PostPosted: Fri Nov 01, 2013 8:01 pm
Year and Trim: 1988 LE
Prob just low fluid. Top it off then work your steering left and right as far as you can and see if it goes away.
-Austin-
yourgrandma wrote:
And thats how I got my mom pregnant.
PostPosted: Sat Nov 02, 2013 8:51 am
Year and Trim: Pullied Clean 2k Black SSEi...
Sadly I bet your rack is gone. I had a 97 GP do this. It acts like the passenger is holding the wheel against where you want to turn. It was a hard friction point inside the rack that caused it. It was random, and only happened turning right. It got worse.
Be very weary of this problem on every exit curve to the highway. When my problem first reared it's head, I was cornering at 65k, and almost took out the guardrail. If you have experienced this before, then you know the feeling of almost shatting your drawers. It was like my ex had ahold of the wheel calling me names trying to put me into the rail for about 3 seconds.
PostPosted: Sat Nov 02, 2013 10:53 am
No, it's not hard to turn. It just makes a slight groan at random intervals. I was gonna check my fluid level as soon as it stopped raining out. I'm sure that's the case, before a shot r&p.
2005 Grand Prix
PostPosted: Tue Nov 26, 2013 12:20 am
I checked the fluid about 2 hours after I had my engine off/ The line was still at the warm/hot mark. So its not low. I wonder if the fluid just needs changing because its old?
2005 Grand Prix
PostPosted: Tue Nov 26, 2013 8:48 am
Moderator
Moderator
Year and Trim: 09 G8 GT
Moved to 2000-2005.
PostPosted: Tue May 06, 2014 4:39 pm
Year and Trim: 2001 SSEI, 2004 SLE
I'm having the same problem. Is the earlier post from Archon a recall that gm is supposed to be responsible for?
1988 SSE-Gone but not forgotten.
2001 SSEI-304,572 miles, 3.5 Pulley, Intense PCM, Intense FWI Spectre filter, 160 tstat, ngk iridiums, belden wires, Silverstars-high and low beam, rebuilt tranny, shift kit, cooler, Dex VI fluid, replace the rear compressor and lines and level sensor, Monroe air shocks in back, FE5 struts and Moog strut mounts, Moog stabilizer bars, AC\Delco control arms.
2004 SLE-Stock, 195,000 miles,oldest son's baby now
2000 Ford Ranger-Stock, 352,000 hard, pizza delivery miles, new control arms (upper and lower), new(used) tranny
PostPosted: Tue May 06, 2014 11:13 pm
No. That is a technical service bulletin to inform dealers on how to respond to relatively common problems.
There are no new unread posts for this topic. Can't figure this out...
MKMike
Tue Feb 06, 2018 12:08 pm
96 SSEi View the latest post
There are no new unread posts for this topic. I cant figure it out
roworld
22
2962
Sat Feb 18, 2012 10:09 pm
There are no new unread posts for this topic. Problem Just Can't figure out!
I/O
14
1465
Sat May 16, 2015 6:19 pm
I/O View the latest post
There are no new unread posts for this topic. The mechanics can't figure it out
Franksdad
Fri Jun 28, 2013 9:02 am
There are no new unread posts for this topic. Can't figure out front end noise..
llllcdllll
14
2932
Sat Apr 20, 2013 7:42 pm
Trinity View the latest post
Users browsing this forum: Google [Bot] and 9 guests
