It is currently Fri Jan 18, 2019 6:45 pm
 Post subject: oil filter
PostPosted: Mon Oct 28, 2013 4:11 am
How do you know when your oil filter is on tight enough?
great car. Wrecked
Burnt Bonny.
 Post subject: Re: oil filter
PostPosted: Mon Oct 28, 2013 9:03 am
Year and Trim: 2004 SLE Premier Edition
2005 GXP
No more than one complete turn after the seal makes contact with the oil filter adapter.
That can be done by hand, don't use a filter wrench.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
PostPosted: Mon Oct 28, 2013 9:12 am
Year and Trim: 2003 SSEi.
LOTS of Mods
Agreed, do not overtighten. The AC Delco Filter says 3/4 to 1 turn once the seal makes contact with the filter housing
See the Image below
PostPosted: Mon Oct 28, 2013 9:29 am
Year and Trim: 2000 Bonneville SE
I always put a quick swipe of oil on the rubber seal and never have had a leak on any of my vehicles.
MW
PostPosted: Mon Oct 28, 2013 10:42 am
I go hand-tight, which is rarely ever more than 1 turn after the seal has touched. I've never had an oil filter leak doing this, and rarely have to find a filter wrench to remove them.
PostPosted: Mon Oct 28, 2013 1:56 pm
That clears my concern. I thought it was like 1/4 turn. I was worried when I had to tighten it way past that. ;)
great car. Wrecked
Burnt Bonny.
PostPosted: Mon Oct 28, 2013 11:07 pm
2004 Bonneville GXP
I tighten 3/4 turn with a wrench after hand tight and fill the oil filter up with oil before installing it. 200,000 miles of doing this, never had a leak or problem.
bobgto65
PostPosted: Tue Oct 29, 2013 5:59 am
I never thought of filling the filter. Just running it a minute and topping it off should cover that. I don't know how to tell if I am burning oil or leaking it.
great car. Wrecked
Burnt Bonny.
PostPosted: Tue Oct 29, 2013 11:11 am
It depends on the engine. These are almost horizontal, I pour just enough on the top to dip my finger in and wet the seal. My G8's is vertical, that one makes sense that you can fill.
Old school chevys and stuff go 1/4 turn usually. Newer stuff gets tighter, because of the designs.
PostPosted: Sat Nov 02, 2013 2:56 am
Year and Trim: Currently searching for a Bonneville...
It's not filling the oil to capacity that's the reason for this. If you spin on the filter dry (no oil in it), when you first start the engine, it's going to take "x" number of seconds for the engine to pump oil into the filter, fill it up, then to the bearings and all other parts that need the oil. If you pre-fill the filter, when you start the engine, the oil pump only has to build pressure, instead of fill an empty oil filter before it can build said pressure.
Running your engine 0.5 seconds without oil is a lot better than running it 3-4 seconds without oil.
Inferno Red 2009 Dodge Caliber SRT-4 125k
PostPosted: Sat Nov 02, 2013 4:03 am
well that's true. It couldn't hurt. seems like it might get messy though. Lucas oil stabilizer is another player in that game. When I first got serious about my Bonneville I started flushing everyother change. Used Lucas, Castrol GTX conventional and a K&N Filter. It was expensive. You said you fill it at about 1/2 way?
great car. Wrecked
Burnt Bonny.
PostPosted: Sun Nov 03, 2013 3:51 pm
I never pre-filled my filter on my Bonneville, and never had an issue. If you were to do it, hold it at the angle you install the filter at, and fill it till just before the oil spills out. The media tends to soak up some oil, so it sometimes takes a bit to get it "full".
There are no new unread posts for this topic. Oil Filter
2002BonnevilleSE
Fri Oct 22, 2010 2:21 pm
2002BonnevilleSE View the latest post
There are no new unread posts for this topic. Fuel Filter
Wed Jul 09, 2008 3:23 pm
lash View the latest post
There are no new unread posts for this topic. Oil & Filter Suggestions
J-ROD
18
1540
Thu Nov 06, 2008 8:38 pm
95SLE View the latest post
There are no new unread posts for this topic. need help with fuel filter
spidey3479
Tue Jun 15, 2010 4:08 am
spidey3479 View the latest post
There are no new unread posts for this topic. Missing Air filter?
Sat Jul 24, 2010 9:59 pm
