It is currently Thu Feb 21, 2019 1:39 pm
PostPosted: Fri Sep 06, 2013 1:59 pm
Year and Trim: 2003 SSEi
wow wee
that middle rear spark plug wire is a PITA to get off. any suggestions?
thx
mike
PostPosted: Fri Sep 06, 2013 7:26 pm
Year and Trim: 2000 SSEI
remove engine cover and straight over the top of the engine standing on the passanger side (lay on the motor a little).. long handle ratchet and a good shove to get it lose.. once its loose its easy. I used a plug socket short extension and a long ratchet to brake it lose.. then a short retchet with a swivel handle to get it out fast. Long handle=leaverage..
when you put the new ones in make sure to use a good ammount of Anti-sieze on the threads and some plug boot grease on the heads for the wires.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Sep 06, 2013 7:46 pm
Also I'm of the group that removes the spring boots and throws them away right away. They make wires way harder to get off in my opinion.
92 Bonneville SSE | L67/4T60E | 72K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 188K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 237k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 186k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 141k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
PostPosted: Mon Sep 09, 2013 1:18 pm
THANK YOU for the great ideas!
Awesome!
PostPosted: Thu Dec 28, 2017 12:12 pm
this is such a HARD plug wire to get too!
Yikes....
PostPosted: Thu Dec 28, 2017 4:56 pm
CLAMP SMALL VICE grips on the boot above heat shield.
then get pry-bar and pop the boot off the plug - works great!!
PostPosted: Sun Jan 07, 2018 11:17 am
Year and Trim: 2003 SLE 208,000 miles
2003 SLE 196,000 miles
First thing I like to do is to remove the bracket in the back used for pulling the engine and holding the cover. That is a little pain to get off but makes things easier down the road. Just leave it off. Unlikely you will need it. Yes it does help hold plastic engine cover in place but cover sits there just fine without it.
There are no new unread posts for this topic. Spark plug confusion
kennyz
16
2501
Sat Jan 23, 2016 12:45 am
There are no new unread posts for this topic. Spark Plug Wires
gweg_b
Tue Mar 27, 2012 7:53 pm
gweg_b View the latest post
There are no new unread posts for this topic. What spark plug wires should I use?
FINN444
Sat Sep 27, 2014 6:42 pm
dissmn8
Wed Oct 08, 2008 10:46 pm
There are no new unread posts for this topic. after spark plug change
chuy10
Mon Dec 09, 2013 1:12 am
Users browsing this forum: Google [Bot] and 13 guests
