It is currently Thu Jan 24, 2019 8:18 am
PostPosted: Thu Jun 27, 2013 6:37 pm
Year and Trim: 2001 SLE
Engine stops randomly all my electric stays on she doesn't turn back on right away mechanics said fuel pressure is fine I'm getting back flow through my exhaust I'm not popping any codes maf is clean. I'm idling low like 6_700 rims engine stopped going 70 and at a stop light any input is appreciated :withstupid: :helpsmilie: :banghead: :sadeyz:
2001 SLE tints | Series III L26 | 180 T-stat |
[b]2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
PostPosted: Thu Jun 27, 2013 6:47 pm
Crank sensor would be my first thought.
PostPosted: Thu Jun 27, 2013 8:03 pm
Wouldn't that give me a check engine light
PostPosted: Thu Jun 27, 2013 8:49 pm
as far as I know, no that would not give you a check engine light but I would also check out the sensor beside the MAF sensor and the MAF sensor common things that will make your car shut off at low RPM's
Member #3848
So Many Mods its drives the Old Lady Crazy
PostPosted: Thu Jun 27, 2013 9:09 pm
As Ryan said, crank sensor usually causes this and sometimes the ICM has without throwing codes. They get warm and cause problems and start right back up after a few minutes to cool.
PostPosted: Thu Jun 27, 2013 10:21 pm
Year and Trim: 2000 pontiac bonneville se
i had an issue like that and turned out to be a crankshaft position sensor
PostPosted: Thu Jun 27, 2013 10:51 pm
Is it something I can test before replacement
PostPosted: Thu Jun 27, 2013 10:57 pm
Found the answer online anyone have pics from replacing one?
PostPosted: Thu Jun 27, 2013 10:59 pm
2004 Bonneville GXP
I had this happen on my '02 due to a bad connection at the battery terminal. It would just die at highway speed.
bobgto65
PostPosted: Fri Jun 28, 2013 9:02 am
Exact problem my daughter was having before I tightened the battery positive terminal that her husband tried to remove when he set off the security alarm. It needs to be tight!!!
There are no new unread posts for this topic. 03 SLE stalling and other issues/idot mechanics/lost sleep
RunningWolf
Tue Dec 18, 2012 7:38 am
RunningWolf View the latest post
There are no new unread posts for this topic. I cant figure it out
roworld
22
2936
Sat Feb 18, 2012 10:09 pm
There are no new unread posts for this topic. Can somebody figure this out?
terrancew3
Tue May 06, 2014 11:13 pm
Archon View the latest post
There are no new unread posts for this topic. Can't figure this out...
MKMike
Tue Feb 06, 2018 12:08 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Problem Just Can't figure out!
I/O
14
1441
Sat May 16, 2015 6:19 pm
I/O View the latest post
Users browsing this forum: napedfep and 11 guests
