It is currently Fri Jul 10, 2020 8:50 am
 Post subject: Need ideas for mods!
PostPosted: Thu Apr 04, 2013 9:34 pm
Year and Trim: 2001 Pontiac Bonneville SLE
Ive almost finished with my 01 sle project. As far as new AC delco fuel and ignition systems. ive also replaced most of the suspension, brakes, maf,etc. I still need to do the uim and lim gaskets and then im ready for some mods.
So, Im looking and asking around and im wanting to get all the hp i can from this n/a 3800.
Examples of what ive heard and seen on here listed below:
-downpipe with high flo cat
-have the intake ported
-cold air intake
Is there anything esle I can do? Is there anything I shouldnt do? would anyone recommend a performance chip? Feedback appreciated! thx.
On a quick note, does anyone kno the part # for the aluminum LIM gaskets or where I can order them from?
 Post subject: Re: Need ideas for mods!
PostPosted: Sun Apr 07, 2013 4:43 pm
Year and Trim: 2001 SLE
Bump I need the gaskets
2001 SLE tints | Series III L26 | 180 T-stat |
[b]2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
PostPosted: Sun Apr 07, 2013 9:42 pm
Ive been informed that this is the ac delco part# 87017816 lim gasket set.
Still would like to kno some mods for hp gain. I kno i cant get a lot. Just wanting to get the most out of it.
PostPosted: Sun Apr 07, 2013 11:16 pm
Year and Trim: 99 Regal GS
A couple things you can do:
HV3 insert: http://shop.zzperformance.com/store/p/9 ... nsert.aspx
Power log to replace the front exhaust manifold: http://shop.zzperformance.com/store/p/9 ... r-Log.aspx
maybe even a 3" downpipe too, though it's probably unnecessary for NA.
You can also get a higher performance cam if you're really willing to put money into it, otherwise there's extended ratio rockers: http://shop.zzperformance.com/store/p/2 ... ckers.aspx
And if I were you and were pulling off the lower intake manifold, I would also port the lower intake manifold. You'll notice right away once you pull it off that it is not the smoothest flowing piece on the engine. It's a cheap mod where you will definitely notice it after you've done it.
You might be able to find a lot of these things cheaper used, however if you're looking to go a lot faster then I would just do a topswap.
1999 Buick Regal GS 3.4" pulley,SLP headers, fwi, pnp, gemini chain w/ other trans mods, 12" brakes, GR2's, STB's, 34mm front sway bar; The Summer DD
1982 Pontiac Grand Prix L36 and an hx35 turbo; It's pretty quick Mod list here
PostPosted: Mon Apr 08, 2013 10:16 am
You will want to find a 2.5 inch down pipe if you can. A 3 inch will make you lose some low end torque.
I can't reiterate this enough: PORT YOUR LOWER INTAKE. ;D You will love it.
PostPosted: Mon Apr 08, 2013 3:10 pm
http://intense-racing.com/Merchant2/mer ... e=3800_HCV
^ iv heard the zzp rockers are a junk.
X2 on the 2.5 down pipe. if your going to be that deep in there doing lim gaskets a cam and some intake porting would be nice.... at least a gasket match. those things are disgustingly made.
l67 swap; 3'DP, power log, CAI, 10.5 wires, 3.5" pulley, autolite 104s, canned tune, 180 thermo, 2 Alpine type Xs, ARC Audio XDi 2000, Big three-0/1 , couple Red Tops, alpine x303, cleared lights, custom trunk.
PostPosted: Sun Apr 21, 2013 10:11 pm
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Are the rockers really worth the money? Do they give you the gains that they claim to?
And which ratio is preferred? Is tuning needed?
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
nos4blood70 wrote:
Literally, cars are drugs.
PostPosted: Sun Apr 21, 2013 10:47 pm
For all L36 model cars, the 1.8 ratio ZZP ER rocker has been proven to make the most power constantly. If you want a roller rocker, 1.8 is the ratio you want for a N/A car. If you're supercharged, 1.9 is the optimum ratio.
Also, lots of good info in this thread :)
http://www.pontiacbonnevilleclub.com/forum/performance-brainstorming/topic25655.html
Joseph
1999 Infiniti G20T - Sold
PostPosted: Mon Apr 22, 2013 12:34 am
ZZP ER rockers are actually sized differently between exhaust and intake valves. IIRC intake was 1.8 and exhaust was 1.84. 1.8 ratio will be an improvement, but ZZP's mix of ratios is slightly better.
There are no new unread posts for this topic. In need of some helpful ideas on this one...
baileyj74
Mon Aug 08, 2011 10:46 pm
Archon View the latest post
There are no new unread posts for this topic. Ideas about source of KR
FiendScurro
Sun Aug 03, 2014 8:42 pm
There are no new unread posts for this topic. no sound,any ideas?????
shawnlee
Tue Jan 17, 2012 11:11 pm
shawnlee View the latest post
There are no new unread posts for this topic. Ideas on mud flaps...
whtiger4229
Fri Feb 17, 2012 12:03 am
whtiger4229 View the latest post
There are no new unread posts for this topic. help needed on some tuneing ideas???
2000-ssei
Sun Aug 25, 2013 7:59 pm
RJolly87 View the latest post
