It is currently Thu Sep 25, 2025 11:55 am
PostPosted: Fri Mar 15, 2013 8:58 am
Hey guys, I have a new rebuilt trans in the car now and am going to go with an external cooler. I am wondering the best way to plug the ports an the radiator connections? Haven't been able to find any threaded plugs(or bolts for that matter) big enough to screw in there, been to hardware, hydraulic supply house, plumbing supply, etc. I believe the cooler was leaking and don't know if coolant could leak from trans ports?
Thanks
2000 SSEi Galaxy Silver with New TEP Trans, A 62,000 mile engine out of grandma's car, all new front and rear suspension KYB/ Energy Suspension.
[url][URL=http://s871.photobucket.com/user/flatlander745/media/image-5.jpg.html][IMG]http://i871.photobucket.com/albums/ab278/flatlander745/image-5.jpg[/IMG][/URL][/url]
PostPosted: Fri Mar 15, 2013 10:45 am
Year and Trim: 2000 SSEI
if they are being bypassed then just remove the lines and blow them out and leave them. you might try a plastic push plug from the help! section of the parts store to keep junk out of them. nothing will happen if they are left open unless the cooler breaks inside then your coolant may leak..
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Mar 15, 2013 11:02 am
Year and Trim: 2003 SSEi.
LOTS of Mods
Honestly if you drive your car in the winter, i recommend leaving the factory cooler
PostPosted: Fri Mar 15, 2013 12:40 pm
on my last car this is how they hooked up the external cooler. Feed the trans fluid to the factory cooler then to the external and back to the trans.
Shane "RedZMonte"
PostPosted: Fri Mar 15, 2013 9:25 pm
I have reason to believe that the cooler is leaking and I do not want to risk the new trans so I am either looking to do the external or I will have to replace the radiator.
PostPosted: Sat Mar 16, 2013 5:09 am
Year and Trim: 2000 Bonneville SE
You should replace the radiator, for peace of mind if for no other reason.
Radiator is a cheap repair compared to all the other things that will be screwed if/when it fails.
Then, if you like, follow redzmonte's advice and add the external cooler as well.
Peace of mind is always worth every penny!
At least that's my thinking....
MW
PostPosted: Sat Mar 16, 2013 8:52 am
LOTS of Mods
buy a new Rad.
When Installed the new Trans I flushed my cooler lines and my Rad
PostPosted: Sat Mar 16, 2013 9:31 pm
ok, so why is this so cheap: http://www.ebay.com/itm/271160108573?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 vs the $12.00 range Spectra??
There are no new unread posts for this topic. Installed Trans Cooler, still seems hot
nubuilder
Thu Jul 21, 2016 5:37 pm
nubuilder View the latest post
There are no new unread posts for this topic. diy trans cooler flush?
bonneville dan-o
Thu Mar 25, 2010 4:16 pm
bonneville dan-o View the latest post
There are no new unread posts for this topic. Trans Cooler Questions
yonkerse
Sat Apr 02, 2011 7:04 pm
There are no new unread posts for this topic. 03 SSEi Trans cooler line NOT 3/8 NPT
Mon May 23, 2011 9:26 am
Jrs3800 View the latest post
There are no new unread posts for this topic. What are the pressures inside trans cooler lines?
imidazol97
Thu Sep 20, 2012 8:23 pm
RJolly87 View the latest post
