It is currently Tue Apr 16, 2024 12:03 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 22, 2013 5:47 pm
Year and Trim: 2001 Pontiac Bonneville SSEI
Honestly, if you want more sound, all you need to change is the mufflers on the back half of the exhaust, and that's only for sound, there is no restriction after the cat. Then you need to decide how far you want to go as far as headers, etc...
Well i want sound but Im not gonna just do mufflers ill do the whole thing.
Blake Hunter
PostPosted: Fri Feb 22, 2013 5:56 pm
We should meet up, you could look at my car for some ideas... :P
88 Cutlass Ciera Brougham International | 120k mi | White w/ Dk Claret Int. | Roller to be S2 L67/4T65E-HD | 1 of ~5100 3.8 FE3 Int'l series
05 Acura RL | 155K mi | Carbon Grey Pearl w/Ebony Int. | The Super-Hooptie Daily
James May wrote:
Hello.
PostPosted: Fri Feb 22, 2013 10:39 pm
Year and Trim: 2000 SSEI
fromtheashes wrote:
SSEiMan01 wrote:
Do a FWI first. You'll be happy you did. :btruestory:
i would do a Downpipe and a Intake to start (your choice of which one.. I did Downpipe). the catback exhaust is good enough flow untill you get alot more mods, untill then its just for sound. The Downpipe sucks on these cars stock, but both downpipe and Intake are not going to be much gains untill you do more mods on top of that.. but they are definatly the place to start.
What's FWI?
FWI=Fender Well Intake (cold air intake)
DP= Downpipe
Shane "RedZMonte"
2004 Z16 Z06: Virgin
PostPosted: Fri Feb 22, 2013 11:52 pm
There's no point in replacing any of the rest of the exhaust. It's not a restriction, no one makes a "performance bolt-on exhaust" and for the cost of custom exhaust work, it's not worth it.
PostPosted: Sat Feb 23, 2013 1:12 pm
Well everything I was planning on doing was:
Bigger Pulley system
Upgrade Fuel Injectors
Cold Air Intake
Upgrade Cams (maybe)
New Full Exhaust
New Thermo
And thats it
Blake Hunter
PostPosted: Sat Feb 23, 2013 1:36 pm
Year and Trim: '02 SSEi
-You want a smaller pulley for more boost
-Stock injectors are good to about 325whp, more on that later.
-Intake, good.
-A cam is a pretty big step to take. Most people do higher ratio rockers instead. Not saying its a bad idea, but i dont know if youre aware of all thats involved.
-A full system isnt going to do anything for you until youre either making serious power or your stock system fell off. The closer to the engine, the more of a difference an upgrade will make. In other words, get headers.
If youre looking for a good bump in power without getting crazy, heres my recipe for bolt on goodness:
-1.8:1 or 1.9:1 rockers and 105# springs for the 1.9s(or mild cam if youre up for the work, but that opens up other mod avenues)
-FWI
-Speed Daddy or SSAC headers
-New high flow cat or catless
-180* stat
-3.4" pulley
-TUNE TUNE TUNE! This is important to get these mods to work right on your car. Dont just order a canned tune from Intense or ZZP, either. Bare minimum, email Dyno Brian and he can usually get you really close.
These bolt ons are usually good for about a 50-60hp gain over bone stock and come in at about $1000 plus any other stuff that comes up.
PostPosted: Sun Feb 24, 2013 2:17 am
Okay thank you ill keep all that in mind
Blake Hunter
There are no new unread posts for this topic. Blown Engine, compatible years?
kmartshopper
26
7026
Thu Sep 06, 2012 6:30 am
ausmth View the latest post
There are no new unread posts for this topic. Mods affect on MPG's
Big Will
Thu Oct 10, 2013 7:27 pm
There are no new unread posts for this topic. interior mods
bonnie02rkt
Sun Aug 23, 2009 11:15 pm
There are no new unread posts for this topic. usual mods?
TheMannn
Fri Jul 06, 2012 4:51 pm
There are no new unread posts for this topic. did some mods on the Bonnie
redzmonte
Mon Aug 12, 2019 3:50 pm
96 SSEi View the latest post
