It is currently Tue Aug 16, 2022 5:40 am
PostPosted: Wed Jan 23, 2013 11:26 pm
Year and Trim: 2003 Pontiac Bonneville
I just bought a 2003 pontiac Bonneville sle today. so far i love it.
I had a cadillac and the dex cool killed the head gaskets, I am wondering if I should flush the coolant with something else.
Also any other maintenace that I should do?
the car has 130K miles
PostPosted: Thu Jan 24, 2013 11:02 am
Change your lower intake gaskets with the updated, either the steel or aluminum framed ones will work fine. Also change out the upper intake manifold with an updated version to stop the issues with the EGR stovepipe and coolant leaks. While doing those jobs replace the coolant elbows with Dormans new aluminum set and then with that all done the car should give you many years of trouble free driving as far as the engine is concerned.
PostPosted: Fri Jan 25, 2013 12:09 am
should i keep dex in it?
PostPosted: Fri Jan 25, 2013 12:27 am
The original dex that is in it I would flush out. From there, if you do a really good thorough flush you can refill it with any coolant you want. I used the good old green stuff in my '03 SSEi, but if you really want to you can go with the new Dex Cool as it has been reformulated and is safer to use now / shouldn't cause issues.
I use the green stuff because it works, is cheaper, and is available basically anywhere if I should happen to need some in a pinch.
PostPosted: Fri Jan 25, 2013 1:12 am
If you upgrade to the Aluminum gaskets and the sleeved UIM, dex should be fine to use. Just make sure you flush the system really well, since Dex doesn't mix with traditional coolant, even though most of the stuff on the market now is a "mixes with any" style.
There are no new unread posts for this topic. 2003 Pontiac Radio Upgrade or Replacement
GhostPlays880
Sun Nov 07, 2021 1:34 pm
GhostPlays880 View the latest post
There are no new unread posts for this topic. 2003 Bonneville SLE LIM job
Crimson3ZXTT
Tue May 26, 2015 3:27 pm
MKMike View the latest post
There are no new unread posts for this topic. 2003 Bonneville SSEi
rynmcdonald
Wed Nov 20, 2013 11:10 pm
rynmcdonald View the latest post
There are no new unread posts for this topic. 2003 Bonneville Question
Ahud7
Wed Jul 18, 2012 1:30 pm
Ahud7 View the latest post
There are no new unread posts for this topic. Update on my 2003 Bonneville
Velo
Tue Jun 29, 2010 2:48 pm
carl View the latest post
