It is currently Wed Jun 20, 2018 5:45 am
PostPosted: Fri Nov 30, 2012 1:25 am
Heater was working fine back on January and now that we are hitting winter I noticed the heater is my working. Everything seems to be fine, it blows air but no hot air coming out. Does anyone knows why is this happening? -Z
[b]THE KNIGHT RIDER[/b]
PostPosted: Fri Nov 30, 2012 5:09 pm
Year and Trim: 2000 se
check your coolant level ,hoses,and you might need to flush the system. also on the temp dial on dash one of the little tongs had folded over screwing up the control setting on mine. easy fix. from my experience you got two possible problems.....cooling system needs attention(any loss of fluid or loss of pressure in system will affect heating), or your tempterature controller in dash. check fuses while your at it...
PostPosted: Fri Nov 30, 2012 9:13 pm
Year and Trim: 2000 SSEI
could also be your heater air door is closed. there are a few topics about this if you search for "airmix actuator" or air door you should find something.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
There are no new unread posts for this topic. ac doesn't blow cold 2000 ssei
saltvick
Sat May 21, 2011 8:58 am
There are no new unread posts for this topic. Heater blows cold
WhiteArrow3800
Fri Sep 12, 2008 6:06 pm
There are no new unread posts for this topic. Car won't blow air - fan runs but no air comes out (FIXED!)
younggunls1
Wed Oct 16, 2013 9:32 am
There are no new unread posts for this topic. Blower Motor Resistor or Blow Mower
whitcd
Sat Dec 29, 2012 7:31 pm
whitcd View the latest post
There are no new unread posts for this topic. AC Not that cold
Hans
Tue Jul 22, 2008 11:11 am
ergoguy34 View the latest post
