It is currently Wed Apr 25, 2018 4:32 am
 Post subject: EGR question
PostPosted: Fri Nov 16, 2012 11:33 am
Year and Trim: 2001 Pontiac Bonneville SLE
I have the egr code on my 2001 SLE, it has 230,000 on it... could the converter cause this? it revs nice dont sound choked up. how can u tell if it clogged? Just wondering before i go and buy an EGR valve... Thanks.
 Post subject: Re: EGR question
PostPosted: Fri Nov 16, 2012 11:52 am
Get under the car and tap on the cat. If it rattles it's bad.
Also if you drive it at night, it will glow if it's bad.
"Penelope" - 2003 SLE - 170k Miles
No name yet - 2000 Honda S2000 - 52k miles
PostPosted: Fri Nov 16, 2012 12:01 pm
How about you clean or replace the EGR valve since that is what the code is for... then worry if you destroyed the cat.
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Fri Nov 16, 2012 12:28 pm
Did clean the egr, no signs of build up anywhere. what brand egr valve replacement do you recommend?
PostPosted: Fri Nov 16, 2012 12:48 pm
Delphi or AC Delco. Get one from RockAuto, the parts stores rip you off on them.
PostPosted: Fri Nov 16, 2012 2:27 pm
Year and Trim: 2000 quicksilver SSEI
What's the code. The I'm working on egr code as we speak. I have a extra egr if ya need one. ;-)
I have replaced mine and was not the problem. After taking with the pros here I find that rearly egr is the issue.
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
PostPosted: Fri Nov 16, 2012 4:56 pm
P0404 i believe ill look when i get home
PostPosted: Mon Dec 03, 2012 11:52 am
Yes its code p0404 on my handheld scanner, p1404 i believe it converts to when i select GM. it just started coming on and acts like its missing at low rpm, sometimes trys to stall when i first touch the gas, i unplugged the egr connector and it runs fine. any more ideas? Hate to buy egr valve if its not it, seen too many post with people changing their egr and it still kicking out the code that why i ask. Thanks again.
There are no new unread posts for this topic. Re: question for you pls. Cabin air filter question.
sonoma_zr2
Tue Aug 16, 2011 10:31 pm
There are no new unread posts for this topic. PCS QUESTION
bslayer
Sat Jan 01, 2011 8:00 pm
There are no new unread posts for this topic. EGR Question
leatherneck
Fri Jun 10, 2011 1:02 am
leatherneck View the latest post
There are no new unread posts for this topic. Rim Question
samples08
Sun Oct 02, 2011 6:44 pm
There are no new unread posts for this topic. Attachment(s) ELC question...
TheMannn
Sun May 06, 2012 9:45 am
TheMannn View the latest post
