It is currently Fri Jul 10, 2020 10:01 am
 Post subject: usual mods?
PostPosted: Fri Jul 06, 2012 2:11 pm
Year and Trim: 2001 Pontiac Bonneville SLE
I've had my bonne for a few monthes now... what easy cheap performance mods are there for the 01 SLE? if any? like best plugs, im hearing of an air box mod... just wondering, maybe their aren't any. Thanks again. ordered my white bonneville club decals this morning, can't wait!
 Post subject: Re: usual mods?
PostPosted: Fri Jul 06, 2012 2:24 pm
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Here's a good read
viewtopic.php?f=12&t=25655&p=261005&hilit=commonly+asked+performance+mods#p261005
Also have your LIM gaskets been changed?
PostPosted: Fri Jul 06, 2012 4:33 pm
Not sure about my LIM gaskets... Anyway to tell? Shes got 227,000 on her and still runs like a champ.
PostPosted: Fri Jul 06, 2012 4:43 pm
Around your upper and lower you should be able to see like a shiny metal for the aluminum one, if it's black, I would go ahead and plan on replacing it.
You would also be able to tell by soppy-ness around the manifold/head/upper intake area, a loss of coolant with no apparent place for it to go..
As for bolt-ons and performance mods, like the link above says. You can upgrade to a FWI, down pipe, PCM, and exhuast for starters, just all depends on what you want to do with your car.
PostPosted: Fri Jul 06, 2012 4:51 pm
89 SkiDoo
In between the lower intake manifold and the cylinder head, if its black, its stock plastic gaskets. If its a grayish aluminum color, its the updated ones.
Are you still running the orange dex cool or is it the green "mixes with any"?
other links from our TECHINFO section....may wanna read through all the sections of TECHINFO, probably answer some questions you have....
http://www.pontiacbonnevilleclub.com/fo ... =53&t=3591
http://www.pontiacbonnevilleclub.com/fo ... =53&t=1061
Other common problems.....
http://www.pontiacbonnevilleclub.com/fo ... 18&t=25362
There are no new unread posts for this topic. Coolant loss without the usual side-effects.
slanej
Mon Jun 01, 2015 12:32 pm
slanej View the latest post
There are no new unread posts for this topic. Brake vibration on front; higher frequency than usual rotor
imidazol97
Thu Aug 21, 2008 12:48 pm
There are no new unread posts for this topic. did some mods on the Bonnie
redzmonte
Mon Aug 12, 2019 3:50 pm
96 SSEi View the latest post
There are no new unread posts for this topic. Mods affect on MPG's
Big Will
Thu Oct 10, 2013 7:27 pm
There are no new unread posts for this topic. Need ideas for mods!
bmoseman
Mon Apr 22, 2013 12:34 am
bs009 View the latest post
Users browsing this forum: No registered users and 15 guests
