It is currently Tue Sep 22, 2020 2:38 pm
 Post subject: car pulls to the left,
PostPosted: Tue May 15, 2012 8:34 am
im thinking its a stuck caliper, recent break job done all around, pads and rotors and one right rear caliper, it was frozen.
new allignment this past weekend ( the car was out of tow at -.41 and - .36 ) back to normal now.
along with new tires and rims. stock size, 235-55-17's
while braking, the car pulls to the left and steering wheel cocks to the right. even after letting go of the brake the steering wheel stays that way for a few seconds and then goes back to normal, I can feel it letting go. as if the caliper is stuck and releasing..
im going to try replacing the front right caliper soon. from what I described would you think the same caliper? or should I go for the Left?
any other possibilities?
PostPosted: Tue May 15, 2012 1:27 pm
I think you are right Jim... But I would like you to replace the front brake hoses first....
PostPosted: Tue May 15, 2012 2:39 pm
ok, didnt think of that, and since i will have to bleed them again I may as well do both fronts.
PostPosted: Tue May 15, 2012 11:09 pm
Were the slide pins in good shape? They'll often have grooves cut across them.
PostPosted: Tue May 15, 2012 11:27 pm
Also, you should never replace just one caliper, or rotor, or anything else. If one went bad, what's to say the other isn't about to go, and ruin any brand new parts you put there? You should always, always, always replace the same things on either sides of a given "axle". Otherwise you run into mis-matched parts, different braking performance, and risk causing/being in an accident and injuring yourself and/or others. Your brakes are the only thing keeping you from blowing through a stop light or sign, or smashing into someone else. It's cheap insurance to do everything, compared to the cost of a hospital stay or a funeral.
Not trying to lecture you, you're a big boy and can make your own decisions, I'm making this post because I care about you and everyone else on this forum, and trying to make sure you make the best choices on your own.
There are no new unread posts for this topic. Car pulls left while braking over 40 mph
beeman212
Thu Dec 26, 2019 6:23 pm
carl View the latest post
There are no new unread posts for this topic. Shaky and pulls to the left going over bumps. Any clue why?
laxmangl
Wed Jul 30, 2008 11:36 pm
laxmangl View the latest post
There are no new unread posts for this topic. 01 SLE left tail lights and left front parking inop
raa1144
Tue Jun 08, 2010 1:11 am
Archon View the latest post
There are no new unread posts for this topic. '01 front end issues. Pulls hard to the right
Oldman
Sat Jan 18, 2014 2:10 pm
Oldman View the latest post
There are no new unread posts for this topic. Front Left HUB
jmal843
Thu Feb 24, 2011 10:26 pm
Users browsing this forum: Google [Bot] and 14 guests
