It is currently Tue Apr 16, 2024 2:00 am
PostPosted: Mon Apr 09, 2012 11:24 am
1992 Bonneville SSEi (Sold)
Is there any tricks to get the y pipe to not leak? I have it on there and clamped so the clamp is hanging over just a little. Should I move it so the whole band of the clamp is on just the y pipe??
Thanks, Keith
2001 SSEi Bumbles
 Post subject: Re: Y pipe? HELP
PostPosted: Mon Apr 09, 2012 11:40 am
Year and Trim: '03 SSEi
You're talking about exhaust right? Weld it.
Chris
2003 SSEi|Galaxy Silver Metallic
PostPosted: Mon Apr 09, 2012 12:45 pm
Is there a way it can be welded while its still in the car?
2001 SSEi Bumbles
PostPosted: Mon Apr 09, 2012 4:17 pm
brought it back to my exhaust place they cant weld it with it still install and I found out that my clamps were not tighten all the way. I just went out and move them back a little bit so they are no longer over hanging the entrance to the Y pipe and I got them as tight as I can and sealed the crap out of it .
2001 SSEi Bumbles
PostPosted: Mon Apr 09, 2012 6:46 pm
Just went out to test it and stills leaks :banghead: What would be the best plan of attack? Weld the Y pipe to the crossover or weld the Y pipe to the rear header and then clamp what ever one doesn't get welded? I bet either way this is going to be a nightmare cause I already have my cat welded to the downpipe and stock exhaust.
2001 SSEi Bumbles
PostPosted: Mon Apr 09, 2012 6:50 pm
I went through this with my Pacesetters. I ended up using regular U-bolt exhaust clamps because they actually pinch the metal. Never had anymore leaks.
1997 Corvette | 55k | Silver Metallic | Z06 wheels | Date-night Hauler/Parts runner
2014 Town & Country Limited | Cashmere Pearl | 95k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 260k | Official Bonneville Hauler
PostPosted: Mon Apr 09, 2012 6:54 pm
Thanks for the info, Ill have to pick up a set of those tomorrow 3inch right? Did ypu have a problem if you Y pipe was on to far that the down pipe wouldn't bolt up? Cause I got mine on and tap it with a rubber hammer a few times and then the down pipe would not line up. Im just hoping that its not to far down now.
2001 SSEi Bumbles
There are no new unread posts for this topic. [Updated] Found a Different Water Leak in a 2000 SE Trunk
Dean
12
3576
Wed Sep 18, 2013 8:09 pm
There are no new unread posts for this topic. Attachment(s) 01 stock SSEi. exhaust pipe/ Y pipe, cannot locate
jddem
Mon Feb 08, 2021 10:30 am
There are no new unread posts for this topic. Exhaust pipe dimensions....
01bonneSC
Wed Jul 09, 2008 12:58 am
bonnevillain View the latest post
There are no new unread posts for this topic. gas cap? Updated 8/12/11
irish91983
21
4391
Sat Aug 13, 2011 1:27 pm
irish91983 View the latest post
There are no new unread posts for this topic. VHT nightshades nightmare! updated with new pic
walnut777
Mon Mar 25, 2013 9:28 am
